DIY Washable Cabin Air Filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05Moose, May 1, 2010.
  1. May 1, 2010 at 7:41 PM
    05Moose
    05Moose [OP] Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Since this keeps coming up with 05 Taco owners asking about the cabin air filter (which won't be there for them because it wasn't installed from the factory until the 06 came out)...and because so many of you probably don't like seeing links to other forums where I have this posted, I decided just to add the thread here too.
    Here's what I did last summer:
    With all the driving on dirt roads (off-roading, cutting firewood, etc), I was getting tired of having to replace my cabin air filter once a month. I was making one from a cheap home filter and the last one went from being white when new to dark brown when I replaced it.
    So I got to thinking, why not make one that lasts forever and can be washed? We use one of the washable filters inside our home that never needs to be replaced. So I purchased another one this weekend (The Web Plus washable electrostatic air filter for $19.97 plus tax) and modified it to fit snugly inside the slot for the cabin air filter. Make sure it's the adjustable filter.
    BEGIN EDIT:
    So many still have questions, so I'll try to answer them right here.
    Q: Where did you find this filter?
    A: I found mine at Home Depot.
    Q: What other parts do I need? (plastic clips, c-channel plastic, etc)
    A: Assuming you buy the Adjustable filter like I did, all the parts come in the package. Other than the tools, EVERYTHING you need is in the filter package. The filter is an adjustable 20 x 25 x 1 Electrostatic Furnace Filter. Here's a link to the filter at Home Depot:
    http://www.homedepot.com/h_d1/N-5yc...splay?langId=-1&storeId=10051&catalogId=10053
    Sandman614 (in post #90) found one at Lowes. Here's the Lowe's link:
    http://www.lowes.com/ProductDisplay...gId=10051&cmRelshp=rel&rel=nofollow&cId=PDIO1
    END EDIT
    Instructions:
    Remove the glovebox, open the filter door, and remove any old filters.
    Cut out an 8" x 8" section from the middle of the filter (Use the middle because the center filter material is attached there with a plastic rivet. The squares are each 1" to make it easy.)
    NOTE: You may want to measure the inside dimensions of your air box first because some have found that they had to trim this a little more so the finished filter was 8 x 8. My finished filter fits snugly at 8 1/8 x 8 1/8 inches!
    Trim up the sides until they fit around the new 8" x 8" center piece. (NOTE: You must use the smaller sides because the height of the larger sides will not fit...the smaller sides are a perfect fit)
    To cut the sides, I used a box cutter. Just apply a little forward pressure to slide the blade while putting a lot of pressure downward.
    Once both side are trimmed down, use pliers to bend the piece back and then easily cut it with the box cutter.
    The areas circled in red are what prevent you from using the larger filter sides.
    Put the pieces together tucking in the corners so they overlap. Then try it out to make sure your filter fits.
    Next, drill holes in the two unconnected corners to the same size as those already in the filter sides. Use two of the four white plastic rivets to connect it. The finished filter should look like this:
    Now just slide it into the slot! You'll want to slide it in with the white rivets on the downward side (toward the floor and fan) because that leaves a very flat side upward which helps complete the seal above.
    That's it! When it's dirty, hit it with the hose or just wash it in the sink then let it air dry.
  2. May 1, 2010 at 7:58 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    I am so doing this. :)
  3. May 1, 2010 at 8:00 PM
    Fireguy67
    Fireguy67 Rebecca and Willow's Opa
    Klaus
    Maple Ridge, BC
    2013 4X4 4 door long bed TRD sport
    No mods- running boards, vent visors all around ,Leer XQ Cap, hood deflector,bed extender, OEM roof rack, Toyota bed mat.Nothing fancy!
    I love it. I know what I'm buying tomorrow.
    Thanks 05Moose. That's so simple its scary!
  4. May 2, 2010 at 11:25 AM
    Crooked Beat
    Crooked Beat Well-Known Member
    GTA
    2021 Tacoma DCLB SR
    That is the best idea I have seen on this forum in a long time.
    THANK YOU!!
  5. May 2, 2010 at 3:24 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    good stuff
  6. May 2, 2010 at 9:53 PM
    Rocko
    Rocko Well-Known Member
    Washington
    2024 TRD Auto
    Yeah, nice mod. I would think that you would have to clean it a little more often, but who cares!!
  7. May 2, 2010 at 9:54 PM
    beetlejuice2275
    beetlejuice2275 Well-Known Member
    Reximus
    Queens, NY
    Drift inspired 08 Reg Cab
    custom ram air. blacked badges, hids, rewired front turn signals and park lights, URD short shifter, Pioneer t-screen (no nav), 10" 1200 watt.
    how much is a cabin filter? that's what you're breathing...spend the few dollars.
  8. May 2, 2010 at 9:57 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Well I saw this and I decided to take a look at how mine looked, There was a mouse nest on top of my filter. :facepalm: Unfortunately the mouse got to make a new friend with my ka-bar and he had some battle wounds when he ran away
  9. May 3, 2010 at 5:54 AM
    Waikoloa Tacoma
    Waikoloa Tacoma Well-Known Member
    At the beach, Hawaii
    2007 PreRunner DC TRD OR
    $25 at the stealership.
  10. May 3, 2010 at 5:57 AM
    beetlejuice2275
    Reximus
    Queens, NY
    you change it once a year....buy it off a wholesale store online and just pay the damn 20 bucks.
    That thing isn't trapping the small stuff like a stock cabin is.
  11. May 3, 2010 at 6:00 AM
    JM76
    JM76 Ride On
    Jon
    SC
    2016 AC SR 4x4
    bone stock save for the block lift that came on it with the open country m/t.
  12. May 5, 2010 at 7:35 AM
    chiledog
    chiledog New Member
    Albuquerque
    2006 Access Cab SR5
    Rack
    $20 every 3 to 6 months, plus sending more plastic crap to the landfill each time? I'd rather rinse & reuse. The "small stuff" still comes in anyway when I unroll the window. Not to mention what the dogs bring into the cab. Thanks, Moose.
    robertjohnsonjr likes this.
  13. May 5, 2010 at 8:38 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    So why don't you just take it out? 'member the old days when air came into the cab unfiltered? :)
  14. May 5, 2010 at 8:59 AM
    chiledog
    chiledog New Member
    Albuquerque
    2006 Access Cab SR5
    Rack
    Then the mouse would be pressed up against the inside of the vent louvers... dead and rotting.
    xenophon likes this.
  15. May 5, 2010 at 9:01 AM
    Memphis
    Memphis Active Member
    West TN
    06 TRD Sport DC 4x4 Short-bed
    Rear TSB, 5100 (0.85), Homelink Mirror, Pop-o-Lock, Front D-Rings, Clear Bra, Wet Okole Seat Covers, Weather-Tech mats, Console Vault, DTRL
  16. May 5, 2010 at 9:02 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    I bought 10 OEM ones off Ebay in a bulk pack that no one else bid on for $48 shipped.........
  17. May 5, 2010 at 9:09 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Great idea. I have those filters in my house and they are awesome. Wash, dry, save money. What's not to like.
  18. May 5, 2010 at 9:27 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    And what happens to the huge piece of reuseable filter you have left over after you cut the small one out?
  19. May 6, 2010 at 8:22 AM
    05Moose
    Jim
    Okay, for those of you who appreciated the idea, I'm glad I could help. For the rest of you, if it's not your thing no one said you had to go this route. You're welcome to keep on doing it the way you are now. It just amazes me how many people complain about this idea when I did it to save ME money in the long run. I've had my truck for 5 1/2 years now. Find the cheapest filters out there, figure on replacing them 4 times a year (that was my situation in the past and sometimes I even had to replace it after a month of firewood cutting), and calculate how much I was spending over those 5 years (and I was doing it the cheap route of cutting up the disposable home filters into 4 filters). I'm going to save a lot of money over the life of my truck!
    And if you do go this route, post it up! I enjoy helping others, so you're giving a little back each time you post.:cheers: After all, why else are these forums around and being used by so many people?
  20. May 6, 2010 at 8:43 AM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Can you buy these washable filters at a hardware store Like ace home depot or lowes, or are they special order?
    Thanks for the awsome write up!
