DIY Washable Cabin Air Filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05Moose, May 1, 2010.
  1. Mar 5, 2014 at 4:25 PM
    #201
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Thanks 05Moose. I picked up the filter at Home Depot. Be sure to get the resizable one, there are others that won't work.
    I looked at my filter it had a pile of twigs and leaves on it, the filter was almost black. I don't want all that stuff in my fan. I'm not worried about micron size particles, those can get in other ways like when the windows are open.
    A new filter cost $20 at walmart, this cost $20. I'm doing it to save money with saves my world.
  2. Mar 5, 2014 at 5:08 PM
    #202
    Dave
    Dave Well-Known Member
    RI/Vt
    08 4x4 Xtra Cab
    Pretty airtight?
    Do you have to wear air tanks while you drive?
    Pretty funny statement.
  3. Mar 5, 2014 at 7:41 PM
    #203
    05Moose
    05Moose [OP] Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    So I should have added..."in comparison to the Tacoma." There's a reason highlander owners have problems with the mold smell if the AC has been running and you don't turn it off and run fresh air well before home (common in a lot of models). They just don't leak air everywhere like the Taco does around door handles, etc. It actually gets stuffy sometimes with the heat on causing us to open windows. And drive home through smoke due to everyone burning with it on Recirc and compare. A lot more smoke gets in the Taco cabin compared to the HL. You just can't argue real-world facts.
  4. Mar 6, 2014 at 4:41 AM
    #204
    Dave
    RI/Vt
    08 4x4 Xtra Cab
    I'm sure you are right, I just couldn't pass it up.
  5. Nov 11, 2014 at 7:08 AM
    #205
    Flynbyu2
    Flynbyu2 Start every day with a smile and get it over with
    Ron
    Folsom, CA
    '10 Tacoma Sport
    Danactive likes this.
  6. Nov 11, 2014 at 8:28 AM
    #206
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Cool but only place I can find the part number is on the K&N site. Must be too new to be anywhere else any cheaper. I have the homemade electrostatic version but will be swapping to the K&N whenever I can earmark 55.00 for the filter and cleaning kit since the cleaning kit is different from the airfilter cleaning kit - electroststic recharge vs re-oiling. Thanks for posting up the info............
  7. Nov 17, 2014 at 10:48 PM
    #207
    Charles135
    Charles135 Well-Known Member
    LA-Orange county
    19 cement trd
    This is awesome idea! I am totally doing this! La Puente Hills Toyota tried charging me about $80 to replace my filter on my 2014 yesterday!
  8. Nov 18, 2014 at 3:57 AM
    #208
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Went ahead and sprung for the K&N filter, cleaning kit & $7 garage banner. I will put my DIY washable electrostatic one up for sale cheap when the K&N arrives.
  9. Nov 18, 2014 at 7:13 AM
    #209
    05Moose
    Jim
    Keep us posted on how you like it. I'm assuming it will collect finer particles as compared to the one I made. Also let us know if leaves and needles get stuck in it. That was my first thought when I looked at it.
  10. Nov 18, 2014 at 10:35 AM
    #210
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Well, seeing as how I live in a neighborhood built on a prairie and the trees here were brought in by the builder plus parking in a garage every night at home and every day at work, I might not be the best reporter of that type action..........
  11. Nov 28, 2014 at 8:01 AM
    #211
    Tcoma06
    Tcoma06 Member
    Cassidy
    Arkansas
    06 SR5 4x4
    Cool... Ill at least give it a try. If i don't like it I can get the filters from "Rock Auto" dirt cheap.
  12. Nov 30, 2014 at 3:38 PM
    #212
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Make sure to install it where ribs run crossways to vehicle. filter is square so it'll fit either way but it sagged in the middle a bit when i fisrt put it where ribs ran with vehicle. Has nice clean air smell to it too.
  13. Nov 30, 2014 at 3:58 PM
    #213
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Popcorn......
  14. Mar 22, 2015 at 9:09 AM
    #214
    Mulloyjr
    Mulloyjr Member
    Lomita CA
    06 Tacoma
    I paid for it once. Then did it myself the second time. Took all about 10 min to do. Using a K&N cabin filter and air filter. Last ones you'll ever need to buy.
  15. Mar 25, 2015 at 8:01 AM
    #215
    MarkMO
    MarkMO What you get with a Brain Aneurysm Rupture
    Mark
    St. Louis, MO area
    '11 ACLB SR5 4x4 Gray Mica
    Discoverer AT3 4S Leer 700 Series Topper
    I usually spray Endust on my furnace filters in the house. I try to change them monthly. A HVAC guy thought that was a good idea. I wonder if that would help?
  16. Jul 6, 2015 at 5:17 PM
    #216
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    Making mine now. I'll show you when finished. :)
  17. Jul 6, 2015 at 5:20 PM
    #217
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Works great and very cheap, I have been using these for a while now.
  18. Jul 6, 2015 at 7:21 PM
    #218
    Silence9
    Alberta, Canada
    Boom, slides in tightly like a glove. Not gonna lie, it's finicky. Tip to save you all some time. Cut your rails to 8" on both sides, slide both grids in without the mesh, then clip off whatever is sticking out, then cut the mesh to the same size as the grid. That should save you at least half hour.
    I've had my truck for a little over 2 years, I started smelling musty, dusty smells through the vents, low and behold, the paper filter was atrocious. Never had to buy one from the stealership, this puppy will be in there 4 life. Thanks OP.
    05Moose[OP] likes this.
  19. Jul 6, 2015 at 8:29 PM
    #219
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Sweet work bro
  20. Jul 6, 2015 at 9:13 PM
    #220
    Silence9
    Alberta, Canada
    Thanks man. Pretty happy with it. No more foul smelling air.
