DIY Washable Cabin Air Filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05Moose, May 1, 2010.
  1. Jul 21, 2010 at 4:19 AM
    #41
    Namyo
    Namyo -
    Nice....just found out the other day that I don't even have one installed!! :eek: Good Timing...
  2. Jul 21, 2010 at 5:06 AM
    #42
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    I would personally check this but i havent seen my truck in a few months because im deployed. But can you even do this with the 05's i know that the filter is not installed on the 05's but can you install one?
  3. Jul 21, 2010 at 5:24 AM
    #43
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    yes
  4. Jul 21, 2010 at 5:25 AM
    #44
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Yay, i have a new project to do when i get home. That and install my darn winch.
  5. Jul 21, 2010 at 7:11 AM
    #45
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Sub'd! I am doing this, when my new one needs replacing!
  6. Jul 21, 2010 at 7:49 AM
    #46
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    This is on my soon to do project too. This, painting the 4x4 out on my mud flaps, and getting my @#(*&$ subwoofer back in and running.
  7. Jul 21, 2010 at 9:39 AM
    #47
    Dimonback
    Dimonback Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    Thanks for the thread- another win on the forum. I did mine a little different- bought the "cut to fit" activated charcoal filter, did the 8" square, and used a duct tape trim and hot glue to stabilize the filter element. It oughta last awhile, and since I bought the 25x 20 filter, I have enough mat'l for another 5 filters.
  8. Jul 24, 2010 at 1:53 PM
    #48
    Everbody
    Everbody Well-Known Member
    Central CA
    05 PreRunner SR5 TRD 2wd
    Looks stock
    A zip tie would do the same as the center rivet and is adjustible!
  9. Jul 24, 2010 at 9:21 PM
    #49
    oneshot808
    oneshot808 Well-Known Member
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    Wet Okoles/Weather tech all around, LED's +HIDS, 6"Fabtech w/ Fox front & rear
    just got the filter in today from logic source. 2 mins to install lol. fyi. but if i have time i'll upgrade to the custom made filter
  10. Jul 25, 2010 at 9:39 PM
    #50
    EricT
    Arizona
    Just finished this. Nice project, simple enough, just make sure your end result is 8x8" exactly. I cut the center grid 8", but the frame adds a slight amount. Easy enough to adjust and redo however.
  11. Jul 26, 2010 at 9:49 AM
    #51
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Me Too! Ordered 4 of them at once...I'm good for a couple years.
  12. Aug 13, 2010 at 11:41 PM
    #52
    Rich Beauregard
    Rich Beauregard Well-Known Member
    Rich
    New London, CT
    17 Taco 4x4 SR5 Access Cab White
    Looks like a great idea! I'll be looking at Home Depot for the kit. Also I did not notice anyone mention it, so here's a little note: After I do the Mod you have given us, I am going to put a bounce dryer sheet on the top of it to both add a little fragrence and it will help filter out the smaller stuff. Thanks again for the gret info, Rich
  13. Aug 14, 2010 at 12:35 AM
    #53
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    You don't want to put it on top you want to put it as the bottom layer before the screen. Not a lot of air can get threw those things. It will plug up fast of it's on the top. I never used that center fastener. I just cut a 8X8 piece out of the side so my filter pack can come completely apart. Why I did that is I added a bottom Hepa fine filter there. It's just disposable. Got miles of it here for computers. Not worth washing.
  14. Aug 14, 2010 at 7:29 AM
    #54
    Rich Beauregard
    Rich
    New London, CT
    Can't put it on bottom or it will get sucked into the fan.
  15. Aug 14, 2010 at 10:30 AM
    #55
    Trap
    Indego Ink TRD OR
    Yes you can put it in the bottom above the bottom screen. But if you just thinking of trowing it in there and not actually using it as part of the filter then of course it would have to go on top,
  16. Sep 19, 2010 at 8:41 PM
    #56
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    subscribed for later
  17. Sep 23, 2010 at 1:10 PM
    #57
    05Moose
    05Moose [OP] Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Well, I finally got around to measuring the filter (I was out there rotating my tires since it was time and BTW I hit 100K miles yesterday!).
    Several of you noted that you had to cut down the grid to have the finished product be 8 x 8 inches. My finished filter measures 8 1/8 inches across each side near each corner. So we all must have different size air boxes!
    I added an edit in the first post to warn people about the differences. Hopefully, that will save others some time.
  18. Nov 10, 2010 at 8:56 AM
    #58
    Dave
    Dave Well-Known Member
    RI/Vt
    08 4x4 Xtra Cab
    Finally did it for my 08.
    Only issue was a trial and error to get it into the box itself but overall very nice and easy.
    Got the kit at Lowes, as they were closer, cost $18 and tax.
    One stupid question, which side goes toward the fan?
  19. Nov 10, 2010 at 9:06 AM
    #59
    Trap
    Indego Ink TRD OR
    If you didn't add layers it probably does not matter. I think the filter we have all be cutting up is symmetric. Grid, plastic fine layer, foam, plastic fine layer, grid.
    I added one extra layer on mine. A hepa fine filter so mine has to go in one way only, hepa down.
    The unfiltered air comes in from the top.
  20. Nov 10, 2010 at 9:43 AM
    #60
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    im confused :confused: does this work or does it not for the 05 tacos?
