DIY Washable Cabin Air Filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05Moose, May 1, 2010.
  1. May 28, 2011 at 7:39 PM
    #101
    jeckel7234
    jeckel7234 Well-Known Member
    Drew
    VA
    05 Tacoma
    Add-a-Leaf, Leveling Kit, 31.5 Nitto Grapplers, Mag-Lite Mod, Anit-Key in the ignition beep mod, Tail gate theft mod, Trifecta tonneau cover, washable cabin air filter,
    great write up, and I made the same mistake, i put it together and went out and tried to put it in and it wouldnt fit, a few curse words later, and a lil more reading i got it
  2. May 28, 2011 at 8:13 PM
    #102
    05Moose
    05Moose [OP] Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Good to know. I just placed the beginning of the note in bold to help it stand out.
  3. Jun 28, 2011 at 8:33 AM
    #103
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I still need to do this................it's time has come.
  4. Jun 28, 2011 at 8:42 AM
    #104
    sprocketdog
    sprocketdog Well-Known Member
    Halifax Pa
    05 Taco 96 Taco 06 TSX 94 extra cab Hilux
    DR coilovers, Camburg UCAs, Dakar rear springs, Bilstien 5150s, Demello sliders, rear plate bumper w/ swing gate, and alot more mods. [IMG]http://i1216.photobucket.com/albums/dd368/sprocketdog1/059.jpg[/IMG]
    This is a great Mod had mine in for over 6 months now
  5. Jun 30, 2011 at 9:48 PM
    #105
    George Wimpleman
    George Wimpleman Active Member
    07 SR5 DCLB 4x4
    Thanks 05Moose. You, and your ideas, ROCK!
    I added an additional layer of the soft filter media to mine. It does not seem to be straining the motor, or reducing the air flow excessively. The central rivet comes apart in opposite directions, and easily handles the extra layer.
    Let the savings begin!!!
  6. Aug 8, 2011 at 2:41 AM
    #106
    deerslayer75
    deerslayer75 Well-Known Member
    Tim
    jersey shore
    11 TRD sport Dblcab Lngbed
    pop-n-lock, mcgard tailgate lock, chrome tube steps, bed extender, chrome brush guard, Fold a cover (G-4) tonneau, weather tech floor mats and rain gaurds, sock monkey: TRD 3rd brake light and whitetail decals, LED bed lights, blue map & dome, 3rd brake light and license plate LED mod, illuminated 4x4 switch, fishing rod holder mod, scangauge II, Remote start & alarm, TW sticker, Flyzeye cupholder light mod
    Great write up! I have a 2011 it's only 2 months old but I will surely be doing this when it's time.
  7. Sep 27, 2011 at 8:09 PM
    #107
    Tacomajoe54
    Tacomajoe54 Member
    Joe
    Pittsburgh
    2010 Tacoma TRD Sport, mgnetic Grey,
    Bilstien 5100's, TSB rear leafs, yellow wire mod, and Tonopro trifold.
    Hey I did this mod today and it went together very well. I had to trim it down twice to fit before final assembly but very slick set up. Thanks again for the info on doing this. I showed my cousin the filter and he will do his Taco also.
  8. Sep 28, 2011 at 5:01 AM
    #108
    eccey
    eccey Member
    Christopher
    Long island NY
    Yes they are available at Home Depot and Lowes
  9. Sep 28, 2011 at 7:52 AM
    #109
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    I just did this yesterday. I got it at Lowes for 19.95. Very easy, once you get the size correct
  10. Oct 1, 2011 at 12:48 AM
    #110
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    Has you guys tried it with the 3m charcoal filters? I did it with mine with the 1700, also where do you find the end pieces does it come with the filter?
  11. Oct 1, 2011 at 5:43 AM
    #111
    05Moose
    Jim
    Everything you need comes with the filter.
  12. Oct 9, 2011 at 9:12 AM
    #112
    BarefootBandit
    BarefootBandit Well-Known Member
    TC UCA OME 884 5100 TSB+AAL 4.10 V6 6spd 285/75/16
    Mine was pretty bad. Not sure how long these leaves have been in there.
    Another tip guys, take compressed air (or in my case, a shop vac with the hose on the exhaust) and blow out the housing where the filter sits. It gets just as filthy as the filter does.
  13. Nov 3, 2011 at 12:59 PM
    #113
    QUE BALL
    QUE BALL Active Member
    Again thanks for saving us all on you your cost saving suggestion. keep up the good work.
    Hopefully I am right that their are no specific year differences that individuals will encounter on 2nd generations Tacomas. If individuals will post the year of ther vehicles that would really help people like me.
    Mine is a 2011 tacoma access cab trd off road.
    Again thanks
    QUE BALL
  14. Nov 29, 2011 at 8:54 AM
    #114
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    DEFINITELY going to try this mod out (if I can find the part, links didn't seem to work for me :( ). Don't like the idea of spending $11 for a cabin filter, esp when there's a reusable air filter and not a cabin filter (ask one of my older brother about it and he said no then shrugged it off - they just don't make em). Plus imo, would go great with the aFe filter I have now (why not have both that you can reuse lol).
  15. Nov 29, 2011 at 12:43 PM
    #115
    05Moose
    Jim
    I just double-checked the links and they are working (from a computer and my Ipod). And they do still carry them, these filters have been around for at least 15 years because I started using one in my home in the mid 90's.
  16. Nov 29, 2011 at 12:47 PM
    #116
    07TacoRidah
    dammit, my freaking internet is being a bitch :mad: took almost 5 minutes to load this page back up from going to the first page. UGH :censored:
    got the links though. thanks for double checking. :cool:
  17. Nov 29, 2011 at 12:53 PM
    #117
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Not to hijack the thread but for those not looking for the DIY solution, as a smoker I went with the febreeze filter and it works great.
  18. Nov 29, 2011 at 1:32 PM
    #118
    Dave
    Dave Well-Known Member
    RI/Vt
    08 4x4 Xtra Cab
    And the cost ?
  19. Dec 24, 2011 at 10:57 AM
    #119
    redz80
    redz80 Well-Known Member
    Brampton, ON
    Tacoma SR5 TRD 4x4 SWB
    subbed for later..........good job
  20. Jan 21, 2012 at 11:04 PM
    #120
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    New Taco owner here (one week!). Stumbled upon this when searching the Cheap & Easy Mods. <--Is why I'm dragging this back out for some flogging.
    The particular filter under discussion here is known to be about the worst-performing home HVAC filter on the market.
    While I'm not one to go praising any company's advice, Consumer Reports has a pretty good track record of testing stuff quite well. This filter came in as a rare Do Not Use: Performance Problem.
    And my own experience backs it up. Even before CR came out with their test of it, I had already concluded it's not worth the plastic it's wrapped in. I had one installed in my home HVAC. After only a month, I started noticing dust accumulation around my HVAC registers. Checked the filter, seemed okay, washed it anyway. Added a high quality 3M paper filter on the clean side of it just to test how it was doing. Checked it a month later and the 3M filter was showing dust accumulation already. This is with the washable filter in line before it!!
    Needless to say, I yanked it out of there and it hasn't returned since. And I have yet to see any more dust around my HVAC registers.
    So, yeah, washable, reusable filters are nice. And they're cheap in the long run. But what good is a filter if it doesn't, well, filter??
