DIY Wedge Camper parts $old Modesto, CA
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by foxrcing07, Sep 4, 2021.
  1. Sep 4, 2021 at 11:49 AM
    foxrcing07
    foxrcing07 [OP] KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    If you have not seen any of these, it’s basically a diy version of the go fast camper
    Example - https://www.tacomaworld.com/threads/how-to-diy-wedge-camper.604686/
    Does not have the space frame (lower section), this is also larger than ripcords, this is 51"x102" inside so 54"x105" outside dimension and ~7.5" tall
    I have the fabric for the tent material it's part ripstop and part coated vinyl, I have zippers, hook and loop, Keder rail and cord, and the assembled wedge as pictured
    It’s about $2400 invested (just in parts and materials)
    I didn’t like how the 1515 had a little flex to it on the roof so I went to the 1530 extrusion
    The frame set into the roof was to be able to have structure for the fantastic fan
    And the single extrusion in front of it was to be able to attach a wind block to push air over the fan
    Extra hardware
    Extra bushings for the hinge
    Bubble seals
    I didn’t like that the 1st order of bubble seal wasn’t 1 continuous piece on the left and right side so I bought 18ft continuous to redo the sides
    52 ft of keder cord
    All YKK zippers
    The plan was originally do the red shaded section in the black rip stop, and the grey section with the grey vinyl so that if turned into the wind or rain it would be as waterproof as possible
    Both fabrics are waterproof tho
    I designed the elevation wedge to accommodate being 6”3 and having feet, I didn’t want the last 10+ inches at the narrow end being unusable space, and I wanted to make sure it was not a tight squeeze to climb from the truck bed to the sleeping area
    nano99, VanDoom, CalTacoma09 and 3 others like this.
  2. Sep 6, 2021 at 7:41 PM
    CalTacoma09
    CalTacoma09 Well-Known Member
    Manteca, CA
    09 TRD Sport DCLB 4x4 Barcelona Red
    A lot of crap and too much money spent
    Very cool, bump for ya.
    foxrcing07[OP] likes this.
  3. Sep 7, 2021 at 8:27 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Damnnnnn. I was looking forward to seeing yours finished with the westfalia style hinges. Good luck with the sale.
  4. Sep 8, 2021 at 4:36 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Wow and GLWS
  5. Sep 8, 2021 at 4:46 PM
    VanDoom
    VanDoom Well-Known Member
    Randall
    2006 AC 4x4 Sport
    Icon 2.5s w/resi ET coils, RXT leafs and struts w/resi, TC UCAs, Hole in Wallet
    Got any pictures of the ripstop? whats the material/thickness of your panels?
  6. Sep 8, 2021 at 4:51 PM
    foxrcing07
    Morgan
    Modesto, CA
    Dirt
    I'll get more pictures when I get home (maybe an hour)
    The top panel is 3 mil, the base panel is 6mil
    VanDoom[QUOTED] likes this.
  7. Sep 8, 2021 at 6:28 PM
    foxrcing07
    Morgan
    Modesto, CA
    Dirt
    Updated the photos of what’s included
  8. Sep 8, 2021 at 6:31 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    So... where do I place my order?
  9. Sep 8, 2021 at 6:37 PM
    foxrcing07
    Morgan
    Modesto, CA
    Dirt
    I wish I could place my order for this to be done, I have hundreds of hours into it, and reworking stuff to be exactly how I wanted it
    I even had most of the steel for the for the base, but some has since been reallocated to a different project
  10. Sep 8, 2021 at 10:18 PM
    MTNROMR
    MTNROMR Well-Known Member
    Cy
    Jackson, CA
    2014 TRD Sport DCSB 4x4
    Build thread in signature.
    do you have a layout of how you were going to do the base?
  11. Sep 9, 2021 at 7:56 AM
    foxrcing07
    Morgan
    Modesto, CA
    Dirt
    I do not, I was just going to build it on the truck I had rough dimensions
  12. Sep 14, 2021 at 10:49 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  13. Sep 21, 2021 at 1:04 PM
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    Free bump
  14. Oct 1, 2021 at 3:55 PM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
  15. Oct 4, 2021 at 11:41 PM
    VanDoom
    Randall
    2006 AC 4x4 Sport
    Still available?
  16. Oct 5, 2021 at 7:59 AM
    foxrcing07
    Morgan
    Modesto, CA
    Dirt
    yes
  17. Oct 11, 2021 at 4:27 PM
    foxrcing07
    Morgan
    Modesto, CA
    Dirt
  18. Oct 22, 2021 at 1:45 PM
    mikeymorra
    mikeymorra Well-Known Member
    Mikey
    Solana Beach Ca.
    Toyota Enthusiast current Rig 2015 DCSB
    Flux Capacitor,10,000 Jigawatts,Fully Pimped.
    Might be interested in the Xped duo...
  19. Oct 26, 2021 at 8:39 PM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    Dang a lot of work went into this!
