DIY: Wiring after-market lights
Discussion in 'Technical Chat' started by rhoppas, Mar 6, 2008.
  1. Oct 2, 2008 at 6:40 PM
    #41
    climber-420
    climber-420 I love tight cracks
    CO
    2004 Gold Ext Cab TRD 3.4L V6 Manual
    255/85/16 BFG KM2's, 3" OME lift, Dakar's, Nitrochargers, Grey Wire Mod, ARB Bumper, ARB CKMA12 air compressor, WIts End Pacifier, Warn M8000, Uniden 520 XL CB, rear diff breather mod, full time power to aux 12V outlets, Rago Fab ditch brackets, Titan Rod Vault, Extreme LED's front and rear,
    thanks for all your help rhoppas. might just be better to take the lights off, and the wiring and put some hella 500's on there with new wiring.
  2. Oct 2, 2008 at 6:45 PM
    #42
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    It's always a pain in the ass to figure out someone else's wiring.... :rolleyes: I've done it. I hate it. Just rip out all the wires after the the lights, and redo it yourself with new wire, relay(s), and switch. Then you know it's done right. :thumbsup:
  3. Dec 4, 2008 at 7:41 AM
    #43
    mpreiss
    mpreiss Attack Life.
    Capon Bridge, WV
    07 D.cab 4x4 w/3" Lift
    3" Pro comp Suspension Lift Fog light Mod. Tinted Front windows 15% (match rears) Tonneau cover Halo head lights K&N filter.
    Hey Philly74- is that how all those types of halos are made or were yours just messed up? And did you get them all working good now.?
  4. Mar 23, 2009 at 8:57 AM
    #44
    Troubletoo
    Troubletoo Active Member
    Houston
    2008 Black V6 Toyota Tacoma
    Hey Philly74, I think that I have the same lights as you but I haven't hook it up yet. Iam still doing some research before going at it. If you have any suggestion or have figure it out, please let me know. Thanks
  5. Mar 23, 2009 at 7:31 PM
    #45
    mpreiss
    Capon Bridge, WV
    i have these lights installed now and mine worked out great. Let me know if i can help you. Check out my pics they should be in there.
  6. Mar 23, 2009 at 10:24 PM
    #46
    Troubletoo
    Houston
    Hey mpreiss,
    If you can be of any assistant, I would be forever be greatful. I've got these lights for a few days now and I still can't find very much information on how to install them. I can get the lights mounted on my truck with no problems, but it's the wiring that Iam a little hesitant about. Please let me know how you did it, cause I would love to get these on asap. Oh if you have any recomendation on what type of light bubs I should use, cause yours looks pretty bright. Thanks :)
    Vincent
  7. May 6, 2009 at 4:51 PM
    #47
    BioMed80
    BioMed80 Well-Known Member
    Colorado Springs, CO
    09 Regular Cab
    3" ReadyLift Kit, 31x10.5x15 General Grabber AT2s, AFE Drop-In, Bull Bar, Hella 500FF, Secondary Filter Removed
    Not sure if this has been posted before, but I've had a heck of a time trying to find it. Here are the wiring posts for the Toyota switch (p/n 00550-35976). They don't come with any instructions. Hope this helps. I found this on a Rav4 site. LOL. I believe the switch will illuminate only when turned on if wired this way.
  8. Jun 19, 2009 at 11:04 PM
    #48
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    Does the relay HAVE to be mounted or can it do its thing and dangle like the rest of the wires?
  9. Jun 20, 2009 at 7:15 PM
    #49
    rhoppas
    rhoppas [OP] Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    I suppose it could dangle. You would just want to make sure it doesn't make contact with anything to short out the connections. And you would have to make sure that, over time, the wires do not come loose from the relay connectors. i would think you could find someplace to mount it about anywhere....just to be safe.
  10. Nov 23, 2009 at 11:04 AM
    #50
    Atron22
    Atron22 Well-Known Member
    San Felipe Peublo, New Mexico
    05 Taco Double Cab 4x4
    K&N Cold Air intake 77 Series, 3 inch leveling kit front, AAL w 1 1/2 inch block, rear Pro Comp ES9000 Shocks, Dynomax Catback Exhuast.
    Awesome!!! Thanks, this is what I have been looking for. Step by Step wiring or more clearer directions. Very Very Helpful.
  11. Nov 25, 2009 at 2:47 PM
    #51
    Atron22
    why am I blowing te inline fuse? I wired it according to the way you did yours step by step. So why am I blowing the inline fuse?
  12. Nov 25, 2009 at 3:02 PM
    #52
    rhoppas
    Topeka, KS
    You apparently have something different. You probably have something grounded that shouldn't be. Are you using a lighted switch with 3 terminals? You may have the ground hooked to the wrong terminal. Verify which terminal is the ground.
  13. Nov 26, 2009 at 6:17 AM
    #53
    Atron22
    Yeah I have a lighted switch with 3 terminals. So verify from the switch and not the relays.
  14. Nov 27, 2009 at 8:10 PM
    #54
    Atron22
    Ok. so I wired the lights again and I am still blowing the inline fuse. I am running the Pro Comp 100 lights and the inline fuse that came with the switch kits is using a 30A fuse. would running a different fuse work? How would I bypass the relay and run it straight from the battery?
  15. Nov 27, 2009 at 8:23 PM
    #55
    rhoppas
    Topeka, KS
    PM sent...
  16. Nov 27, 2009 at 8:44 PM
    #56
    rhoppas
    Topeka, KS
    Here is a good diagram of the wiring...
    Dewey7015 likes this.
  17. Nov 27, 2009 at 8:49 PM
    #57
    Atron22
    Ok the diagram is similar to how i have it wired, except the wiring going to the negative terminal of the battery. Those would be the white wires from the lights, right?
  18. Nov 27, 2009 at 8:54 PM
    #58
    Atron22
    What did you use to connect the two white wires from the lights to the negative terminal of the battery?
  19. Nov 27, 2009 at 8:57 PM
    #59
    rhoppas
    Topeka, KS
    I have mine connected to a good ground in the front of the truck. I have nothing connected directly to the battery (in step 10).
  20. Nov 28, 2009 at 12:03 PM
    #60
    tinytdog
    tinytdog Member
    Tim
    Seattle
    06 Tacoma SR5
    My inline fuse is on the wire from the lights to the relay instead of on the wire from the battery to the relay.
    Is this bad? Or does it make a difference?
