DIY: Wiring after-market lights
Discussion in 'Technical Chat' started by rhoppas, Mar 6, 2008.
  1. Mar 11, 2012 at 3:36 PM
    #101
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    I know you suggested using a coat hanger to get the wires from the engine bay to the interior...I looked from both sides of the wire loom there already. Looks super tight. So if you're pulling three wires through for a switch how the hell did you get them through that grommet with the loom already there? Looks daunting.
  2. Mar 26, 2012 at 12:29 PM
    #102
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Get some wire lubricant used for pulling wire through conduit. Sold in most hardware stores. Will make it much easier to pull the wires through to boot surrounding the wire bundle that is there.
  3. Jun 4, 2012 at 2:23 PM
    #103
    ross123
    ross123 Well-Known Member
    fort bragg
    ok so what size fuse do i use from the fuse box to my switch? i have a lighted switch i think its 15 or 20 amps. i already bought everything but i gotta go back for the fuse it self. so any ideas?
  4. Sep 8, 2012 at 5:47 AM
    #104
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Subd! Awesome and very straight forward write-up
  5. Oct 30, 2012 at 3:52 PM
    #105
    witter beach
    witter beach Active Member
    seattle
    2008 tacoma trd offroad
    Thanks for the info on switches and fuse taps. I bought a lighted rocker from the dealer
    $12.00, and installed some auxliary lights mounted under the rear bumper. I connected
    to the battery when I could have used a fuse tap and made it a little simpler. WB
  6. Feb 17, 2013 at 8:27 PM
    #106
    randytho
    randytho Member
    SR5 4cyl 4x4
    I just bought the Amazon kit made by kramer acc. I would like them to behave like the oem lights. (As in they go out when the high beams come on.) I am looking at the service manual diagrams and it looks like if the fog relay switch in the kit is powered from the RH LO HEAD 10A fuse location (using the add-a-fuse) then it would have this behavior. (Instead of the tail fuse.) It looks like this would simply mimic the factory wiring. I have linked the manual pages below. Any comments to support or disagree?
  7. Mar 22, 2013 at 10:43 AM
    #107
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Can I buy a OEM fog light switch and mount it in the blank slot?
  8. Mar 22, 2013 at 10:44 AM
    #108
    stump jumper
    Bill
    Texas
    KY jelly or vaseline
  9. Apr 2, 2013 at 11:15 PM
    #109
    bkrdave36
    bkrdave36 Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Front OME Springs, Upper Control Arms, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    Once again this website will save me money by doing it myself instead of paying someone else. Thanks!
  10. Apr 2, 2013 at 11:30 PM
    #110
    acdronin
    acdronin Well-Known Member
    Hell yeah! That's what I love about TW, I've saved thousands not having to pay people, plus It feels better knowing you did it yourself and learned along the way.
  11. Apr 16, 2013 at 7:15 AM
    #111
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
  12. Apr 27, 2013 at 10:15 AM
    #112
    bkrdave36
    Dave
    Wittmann,AZ
    There is one 20 amp inline fuse and one mini fuse tap used. As far as the other questions, I cant help you. Sorry.
  13. Apr 28, 2013 at 11:13 AM
    #113
    PhantomVirus
    PhantomVirus Well-Known Member
    Ron
    People's Republic of NJ
    2012 Super White TRD OffRoad Double Cab
    Don't steal my tailgate Mod, Hardwired Valentine1 Radar Detector, Smitty N-FAB Nerf Bars, Led lights (Maps, overhead & rear License Plate), Debadged, TRD rim center covers, Replaced Chrome Grill with OEM Super White, PlastiDipped Toyota Logo on Grill BLACK, Distinct Offroad Custom light bar
    You can remove one of the firewall grommets, cut it and then feed the wires through it.
    Reinsert the grommet back into the firewall to keep things waterproof and add a bit of silicone sealant on the wires when done.
    You do NOT need to use the Wire Loom bundle.
    The grommet I used is approx. 6 inches closer to the passenger side of the car from the wiring bundle. The grommet is in the firewall and seems to serve no purpose other than to seal the open hole in the firewall.
    I do not know why the hole is even there.
    Will try to take a picture or two and post here - I used this hole in the firewall to wire my RIGID light bar.
    BTW you also need to make a SMALL hole in the carpet to get the wire into the cabin. If you do it on a sunny day it's super easy to see where the hole needs to go since the light will shine through the carpet.
    I used an XACTO knife to slit the carpet but I would guess your could use a sharp pencil to push through if you needed to.
  14. May 25, 2013 at 10:54 AM
    #114
    Geem750
    Geem750 Well-Known Member
    Brandon
    Okanagan, BC
    07 DCLB
    Grillcraft grill, ultimate toytek 3" lift, shorty antenna, blacked out badges, rear diff breather, Kenwood 6990 HU, wet okoles, weather techs, extra D-rings, Cruisin offroad bolt on sliders, Treklights 18" LED bar
    bookmarking
  15. May 25, 2013 at 12:02 PM
    #115
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Do yourself a favor & make it simple. Go to www.okledlightbars.com and buy their $20 pre wired harness with relay. You're probably going to spend that much in supplies anyways...
  16. Oct 7, 2013 at 8:46 PM
    #116
    TACO FOR LIFE
    TACO FOR LIFE Well-Known Member
    Seth
    texas
    07 PreRunner
    OK im a little lost....or a lot. im in the process of putting 4or5 2x2 led pods on my truck but im getting lost in all this. How many relays would i need? can i use the same process as in this thread? will that much light kill my stock battery? if so should i get a second battery or can i get a bigger/better battery. i think this is most of my questions but if not ill bring them to the table.
  17. Oct 7, 2013 at 8:49 PM
    #117
    TACO FOR LIFE
    Seth
    texas
    07 PreRunner
  18. Oct 8, 2013 at 5:23 PM
    #118
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Ok so should I wire 2 kc daylighters and 2 hella 500s on the same 5 pin relay or use 2 4 pin relays? I want to wire them to turn on either or, or turn on all 4. So I think I would need 2 switches? How would I wire that?
  19. Oct 9, 2013 at 11:45 AM
    #119
    jimmyd
    jimmyd New Member
    2013 prerunner sr5
    Hi! I just joined, had my 2013 Tacoma about 2 months now. I am installing fog lights, and the wiring is giving me some problems mainly no instructions or wiring digrams. Any one know what to do with this mess of wires?
  20. Oct 11, 2013 at 3:56 PM
    #120
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    A picture or a diagram of what you have might help
