DIY: Wiring after-market lights
Discussion in 'Technical Chat' started by rhoppas, Mar 6, 2008.
  1. Nov 15, 2013 at 1:35 PM
    #121
    TACO FOR LIFE
    TACO FOR LIFE Well-Known Member
    Seth
    texas
    07 PreRunner
    ok so i followed this to the T and no lights when i hit the switch. im wondering when i check the relay for power it has it going in but i checked the other prong with the lights on it and the one with the switch and neither have power. does this mean i have a bad relay or could something else be wrong:confused::confused::confused:
  2. Nov 15, 2013 at 7:48 PM
    #122
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Make sure you have a good solid ground first, re check everything step by step
  3. Nov 16, 2013 at 12:31 AM
    #123
    acdronin
    acdronin Well-Known Member
    yeah, check grounds, swap out relays to see if that's it, possible switch could be bad too
  4. Dec 8, 2013 at 8:09 AM
    #124
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    sub'd. just bought some kc's
  5. Feb 2, 2014 at 6:38 PM
    #125
    BBell
    BBell Well-Known Member
    B
    Northwest
    13 Tacoma TX
    2013 Tacoma TX 4.0 6 Speed Manual Volant CAI and air scoop Volant throttle body spacer DigiFit Weathertech Kevlar Seat Covers - Grey Interior LEDs Fab Fours PreRunner Bumper Body Armor Rock Sliders Painted radiator Rigid Industries 3x3 D2's DTL lighting kit Rigid Grill and 20" SLR2 light bar Plasti- badges Plasti- front grille surround Plasti- rear bumper MATT black rear taillights Night Raider rear LED light bar :D
    I've got some Hella Blacks in the mail right now. I have no doubts this will be a huge help to me. Thank you.
  6. May 6, 2014 at 2:53 PM
    #126
    Manwithoutaplan
    ID
    So much sub'age.
    Working on getting a bunch of switches wired up.
  7. May 6, 2014 at 9:09 PM
    #127
    kruizner
    kruizner New Member
    Nor Cal
    09 4x4
    lift, wheels, tires, bull bar, light bar, grille, headlights
    Just adding a few photos to demonstrate where I tapped into the engine compartment fuse box for power to the relay and ultimately to power the light bar, as well as how I wired my illuminated dash switch to the fuse panel inside the cab all using 3 add-a-circuit (fuse taps).
    Wiring steps; 1. power lead and ground from aux light to relay. 2. Relay power lead (with in line fuse) to EFI #2 on engine fuse panel and ground to car body. 3. yl wire from relay to illuminated light switch in cab. 4. As the photo shows, my illuminated OEM looking switch has 4 wires - ground, illumination, power lead to relay and power from (in cab) fuse panel to switch.
    EFI #2 allows circuit to disconnect when ignition is off. This assures the aux light will be off when you turn the key off.
    http://www.tacomaworld.com/forum/attachment.php?attachmentid=270844&stc=1&d=1399428863
    The 2nd photo is how it looks with the fuse tap in place.
  8. Jun 28, 2014 at 9:58 AM
    #128
    Grakyn
    Grakyn Well-Known Member
    Kyle
    Prince George, British Columbia, Canada
    2013 DCLB TRD Sport
    Toytec Ultimate Lift, Leer truck cap, Kenwood D710a ham radio, OTRATTW switches
    This fuse tap just made my life so much easier.
  9. Jun 29, 2014 at 7:14 PM
    #129
    PiratePug
    PiratePug New Member
    Candler NC
    2011 4x4
    been looking around for a little while for the easiest and most correct way to wire aftermarket lights for my truck. this was very clear and concise thanks
  10. Jul 7, 2014 at 7:43 AM
    #130
    TRDh4vok
    TRDh4vok Well-Known Member
    Gil
    Palm Beach County
    '09 TRD PreRunner Sport
    -4" MaxTrac Spindle lift -5100 RCD Bilstein's -1/2" Strut Spacer driver's side (Taco Lean fix) -1/4" Strut Spacer passenger side (Taco Lean fix) -4" Tapered Blocks -Extended length U bolts -Front Skid Plate -Exhaust Tip -Tube Steps - Silver -Bed Extender -LEER Tonneau Cover -Rampage Roof Cab Lights -Rampage Tailgate Light Bar Six Function SUPERBRITE with Reverse Lights, Running Lights, Brake lights, Emergency Hazard and L & R turn signals -exLED Toyota Tacoma Custom interior LED Light Kit -PIAA Xtreme White Plus head lights and fog lights -NITTO Terra Grapplers 285-70-17 -30" Avec CR-Series Led Light Bar in bumper grill -Two 6.5" Led light bar's attached to the A pillars -Hood hinge bracket mounts from Famous Fabrications -Exhaust muffler Aero Turbine AT2525XL -OEM Roof Racks -OTTRAW Rocker switch -Stant locking gas cap -Large T emblem and mid mount bracket from Diaz Fabrications
  11. Jul 11, 2014 at 11:52 AM
    #131
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
  12. Jul 11, 2014 at 6:03 PM
    #132
    gearcruncher
    Canadain bumper technician
  13. Jul 21, 2014 at 2:41 PM
    #133
    P Dub
    P Dub New Member
    Louisian
    2014 Tacoma TRD
    I got a curved 50" light bar, and I need mounts for the roof. Any suggestions on where to buy them? 2014 taco
  14. Jul 26, 2014 at 3:46 PM
    #134
    Tacoma VT
    Tacoma VT Well-Known Member
    R. Kessler
    Vermont
    10 DCLB TRD sport
    OME 884s, Bilstein 5100 Shocks, Icon 3 leaf progressive AAL (with overload in), Rear leaf TSB, ImMrYo mirror relocater, ARE Z series cap, Hi Lift jack W/ DIY mount, trimmed Mud Flaps, Devil Horns by Andres, EGR In-Channel rain guards, LED bed lights, Weather Techs
    Sub'd
    Thanks
  15. Aug 15, 2014 at 6:15 PM
    #135
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I have a 2014 DCSB. I am trying to wire LED halos into my DRLs so that the LED's have power while my DRLs are on. There are three wires coming out the back of my DRL: Green, White with a black stripe, and Blue. I need to know which wire is which so I can splice the proper wire for the LED into it. I called at least 6-7 dealers and they all refused to tell me cause they can't give me information that would help me mod my truck. Green, White, Blue. Which wire is which?
  16. Dec 25, 2014 at 7:41 PM
    #136
    burtonbrd31
    burtonbrd31 Member
    Northeast
    2014 SR5 Double Cab
    Tonneau Cover,Blacked out badges, LED light bar, Canadian Lockers, Fog Light mod.
    What type of fuse tap did you use 10amp ect?
    Also in section 7. What/ Where is the 20a inline fuse?
  17. Dec 30, 2014 at 1:23 PM
    #137
    bbersanti
    bbersanti Well-Known Member
    Ben
    Arvada, CO
    2011 Access TRD Offroad 4.0 V6, 6-spd
    Weathertech's, All-Pro APEX Front Bumper, Maglite seat mount, Fog Light Anytime, Aux Blue Sea Fuse Box, Toyota Bed Mat, color-match grille, 21" LED bumper Light bar, Redline Hood Struts, Full OME 3" Lift
    Awesome thread. Great, thorough instructions. I will definitely be using this to install my new lighting once my other kit shows up!
  18. Feb 18, 2015 at 6:32 PM
    #138
    300AACTaco
    300AACTaco Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    Sub'd for later reference, great write up!
  19. Mar 10, 2015 at 7:25 PM
    #139
    yodatoyota
    yodatoyota Scrub
    tim
    Barrie Ont. Can
    2021 TRD OR 4x4 sb
    Empty wallet mod
    sooo when you connect the 14 gauge wire to both off road lights are you using the 22 connecter or just a 14??
  20. Aug 1, 2015 at 10:31 AM
    #140
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    Nice write up sub'd 4sure& thanks!
