DIY: Wiring after-market lights
Discussion in 'Technical Chat' started by rhoppas, Mar 6, 2008.
  1. Aug 12, 2015 at 4:44 PM
    #141
    TimsTaco
    TimsTaco Well-Known Member
    Tim
    Moncton, NB
    07 DCLB SR5 Sandstone Metallic
    OEM Fog lights, headache rack, work lights, Tailgate Theft Deterrent (hose clamp), Tailgate Reinforcement, Roll'n'Lock tonneau cover, OEM Inverter
    Sub'd for future reference. :pccoffee:
  2. Sep 9, 2015 at 3:46 PM
    #142
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    @rhoppas , I see that your fuse tap has little "fingers" longer thant the stock fuse. I was wondering if it does fit nice in the fuse box even if it is longer?
    Thx!
  3. Sep 23, 2015 at 10:35 PM
    #143
    AKTACOTRUCK
    AKTACOTRUCK Well-Known Member
    Shawn
    Red 2008 Tacoma TRD Offroad Double Cab
    Bull bar, but more to come
  4. Sep 25, 2015 at 2:53 AM
    #144
    Kemosabe
    Louis
    So I tried the fuse tap with the longer "fingers" in the fuse box and it does fit. Didn't knew about it before seeing it on TW, it is a nice thing :p
  5. Sep 25, 2015 at 3:10 AM
    #145
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Sub'd for future. Thank you for the write up.
  6. Oct 20, 2015 at 9:43 AM
    #146
    Bigredtaco06
    Bigredtaco06 Member
    Adrian
    North las vegas
    Sr5 4x4 double cab 6ft
    None yet
    Great thread! Just bought my 42inch curved light bar. Posting pics soon
  7. Jan 30, 2016 at 1:42 PM
    #147
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    if a switch say a ottraw or oba switch has 4 wires from it 1 positive, 1 negative, 1 accessory, and one for the led light then thats where the fuse tape will connect to correct?
  8. Apr 26, 2016 at 11:25 PM
    #148
    Dom.com
    Dom.com New Member
    Dom
    2004 Base model 4x4 v6 half cab manual
    fabtech front coil overs, k&n cold air intake, throttle body spacer, flow master delta 40, bilstein 5165, firestone air bags, onboard air from firestone
    Looks like you might be a bit more savvy at electrical. Maybe one of y'all could help me out. So I split off my dimmer switch to attempt to dim some accessory switches and a backlit air pressure gauge for my air bags. The dimmer works but in reverse. The dash lights dim as the switches and gauge get brighter, and the dash lights brighten as the switches and gauge dim. The dimmer switch has 3 wires a negative, constant load source and the dimmed output. I tapped the dimmed output as the load for the switch lights and gauge.
    Is there a better place to get power from thats further down the line that won't act this way or is this some other sort of problem?
  9. Apr 27, 2016 at 3:45 AM
    #149
    Ryan DCFS
    Ryan DCFS Elevator guy
    East Bay Area
    09 DC long bed TRD silver streak
    Okay... So a few things pop up in my head... In your last sentence you say;
    "The dimmer switch has 3 wires a negative, constant load source and the dimmed output."
    "constant load source" is a bit of an oxymoron.
    "constant" (in my experience) refers to a constant "hot." (directly connected to the positive terminal of the battery.)
    "load" is the component the requires power (current multiplied by voltage)
    "source" is the input supplying power.
    That being said, I don't know the exact characteristics of the OEM dimmer circuit...
    So essentially everything I say from here is based on speculation, so take it with a grain of salt.
    I can only assume that it is a rheostat that varies the resistance between the source (12v when ignition is on/acc) and the load (dash lights).
    When the resistance is increased, the lights get dimmer, when it's decreased, the lights get brighter.
    Somehow you've managed to add an alternate leg.
    Electricity takes the path of least resistance. The first thing I can think of is that you possibly have tapped into the source (incoming power) and created 2 paralleled circuits, where, as you increase the resistance of the oem circuit (dimming the OEM dash lights), you increase the resistance of that leg, thus diverting the current through the circuit you added, increasing the brightness.
    If parallel, that might be the issue. However, if you add your second circuit in series, you would decrease the operating voltage of the entire circuit.
    The only certain solution, with the given info, is to make the additional circuit completely separate, with it's own dimmer. There's probably someone that has a better solution, but I've never tried to add lights to a stock dimmer circuit.
    See if you can find an accurate wiring diagram..?
  10. Apr 28, 2016 at 12:30 PM
    #150
    Dom.com
    Dom.com New Member
    Dom
    Thanks for the constructive criticism. :thumbsup: I haven't got it figured out yet but your reply has put me in a better direction.
  11. May 29, 2016 at 7:32 PM
    #151
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Could you help me identify the 4 wires of my switch? They're from Amazon and did not come with instructions or wiring diagram.
    Thanks.
  12. Jun 17, 2016 at 6:09 PM
    #152
    baboltin
    baboltin New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    Good to know
  13. Jun 26, 2016 at 11:18 PM
    #153
    koda925
    koda925 Well-Known Member
    Dakota
    Ogden, UT
    2015 DCSB TRD Offroad Auto
    Bilstien 5100's all around, SPC uppers, headlights, tailights
    20160626_230856.jpg Just gotta say, I love this thread!! Thanks a ton to rhoppas for the time he took to write this. I dont think I could have done it without this thread. I did a couple of minor things differently like wiring the switch ground underneath the dash rather than trying to shove another wire through the firewall. Also, I too had to put a fuse in both slots on my fuse tap before it would turn on. Thanks again rhoppas.
  14. Jul 26, 2016 at 8:52 PM
    #154
    cbstewart
    cbstewart Active Member
    Clayton
    Henderson, NV
    2010 Tacoma TRD Off Road DC
    Thanks for this!
  15. Jul 26, 2016 at 8:56 PM
    #155
    cbstewart
    Clayton
    Henderson, NV
    Love the front of your truck. Did you go the eBay route on those headlights?
  16. Jul 26, 2016 at 9:01 PM
    #156
    koda925
    Dakota
    Ogden, UT
    Amazon. They're spec D tuning headlights. 120$ grille and 60$ 34 inch light bar that claims 18000 lumens. 350 total for the setup. Watch out for moisture though. Id recommend sealing everything before installation. No problems so far. EXCEPT for the shitty ass fog lights that came with the leadlights. The housing got melted the second you left them on without the trucl moving. All kinds of bubbles in there... Ugh
  17. Jul 26, 2016 at 11:18 PM
    #157
    cbstewart
    Clayton
    Henderson, NV
    Thanks for the info! I've read a lot on here about people recommending sealing the aftermarket headlights to prevent fogging up, while most others just say to stay away from them because they're not OEM, but no one says much about how well they perform in the long run. I might just have to give them a go myself to see, because they look sweet. Especially for under $200. Thanks again!
  18. Jul 26, 2016 at 11:56 PM
    #158
    koda925
    Dakota
    Ogden, UT
    As far as pwrformance, the Halos arent as bright as i wanted them to be... Cant really see them durring the day to well. But evening/night time you can. The headlights themselves perform better than oem in my opinion. Overall, i think it was worth it for the money i spent. Wiring is a little tricky but any novice, taking their time, should be able to figure it out. Love the light output on the light bar. Went with the 60 dollar one because when i get a rock chip in it, rather replace a 60 dollar light bar verse a 600 dollar light bar. Ill post headlight and light bar picks if you want.
  19. Jul 27, 2016 at 12:04 AM
    #159
    koda925
    Dakota
    Ogden, UT
  20. Jul 27, 2016 at 12:08 AM
    #160
    koda925
    Dakota
    Ogden, UT
    20160712_135630.jpg And this one just for fun. Most favorite pic of my baby right now... :)
