Dj Suisav's (kinda Stockish Build)
Discussion in '2nd Gen. Builds (2005-2015)' started by Dj Suisav, Jul 27, 2015.
  1. Aug 11, 2015 at 12:25 PM
    #81
    DrFunker
    DrFunker Well-Known Member
    You know what though, Saul. I am getting into some deeper shit here. I really need to understand the whole amps/volts/watts thing better.
    For instance, when you were helping me with the socket install you told me to get a certain number fuse but no bigger and that was dependent on the gauge of the wire, correct?
    So could I hook a compressor up to the fuseblock? How much load would it be. What about extra lights? How do I figure all that out?
    Please edumacate me.
  2. Aug 11, 2015 at 12:30 PM
    #82
    DrFunker
    I think this may turn into a big project....this whole fuseblock thing.
    :confused:
  3. Aug 11, 2015 at 1:12 PM
    #83
    Dj Suisav
    Dj Suisav [OP] Well-Known Member
    Saul
    San Antonio, TX
    2011 MGM DCSB Trd Sport
    RIP 2009 Super White DCSB Trd Sport
    Yes it gets a little complicated but knowing what accessory your going to add is the main thing... knowing the amp rating of that "accessory" is the important thing. once you know that then you just get the right size wire that will support that load rating and add the fuse to match the rating of the "accessory" you'll be golden! this link has a chart that dictates what size wire you should.
    http://www.powerstream.com/Wire_Size.htm
    DrFunker[QUOTED] likes this.
  4. Aug 11, 2015 at 1:13 PM
    #84
    Dj Suisav
    Saul
    San Antonio, TX
    I'm am also here to help in anyway i can. if we lived near each other I'd bring a 12'er and comeover and help!:drunk:
  5. Aug 11, 2015 at 1:31 PM
    #85
    DrFunker
    Yeah, thought that too.
  6. Aug 11, 2015 at 1:32 PM
    #86
    DrFunker
    I think you passed this along to me before. I am going to stash it on my build for reference.
    Dj Suisav[QUOTED][OP] likes this.
  7. Aug 11, 2015 at 1:33 PM
    #87
    DrFunker
    So that guy that had the 6 and 12 fuseblocks only has 6's. He said he is doing more with Bussman RTMRs right now.
    What the hell are those? hahahahah
  8. Aug 12, 2015 at 2:37 AM
    #88
    DrFunker
    Saul, what do you think?
    "the Bussmann is a complete kit that I offer. It requires little wiring knowledge since I prewire the boxes for easy installation. My kit includes the Bussmann fuse/relay box (including 5 relays and 10 fuses), all the wired leads, 4 ft of 7 pin switch cable (can be longer if needed), and mounting plate with bolt kit. I offer the battery cable leads if needed as well. It incorporates 5 fused and relayed wire leads that I prewire into a 7 pin cable to power 5 illuminated switches. Additionally it has 4 fused only leads for any other low voltages accessories."
    Dj Suisav[OP] likes this.
  9. Aug 12, 2015 at 7:16 PM
    #89
    Dj Suisav
    Saul
    San Antonio, TX
    This is great, but for how much!
  10. Aug 12, 2015 at 7:17 PM
    #90
    Dj Suisav
    Saul
    San Antonio, TX
    The bussman is that relay block. Where all the wires and fuses connect
  11. Aug 13, 2015 at 3:11 AM
    #91
    DrFunker
    Asking him now. Will let you know.
