DJB1's 2003 Regular Cab
Discussion in '1st Gen. Builds (1995-2004)' started by DJB1, Aug 1, 2015.
  1. Aug 17, 2015 at 8:06 AM
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    Looking good neighbor :thumbsup:
  2. Aug 17, 2015 at 3:01 PM
    DJB1
    DJB1 [OP] Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Thanks @Jiveydude. Seeing your truck on TW over the last year or so only strengthened my regular cab lust.
  3. Aug 19, 2015 at 6:07 PM
    DJB1
    Dave
    SLC, UT
    CBI frame plates arrived a few days ago and today I scored an entire non-ADD front end super cheap.
  4. Aug 22, 2015 at 4:06 PM
    DJB1
    Dave
    SLC, UT
    Got bored, mounted the Cooper ST Maxx 235/85r16's I bought from @ikarus and went for a 75 mile test drive. I think this size looks perfect on a 1st gen. Had no rubbing on stock suspension even making sharp turns across ruts and they won't look too small when I get a suspension lift.
    bigwill837 and ikarus like this.
  5. Aug 22, 2015 at 6:10 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    couplefunones likes this.
  6. Aug 22, 2015 at 8:25 PM
    DJB1
    Dave
    SLC, UT
    Damn! I admit I was suspicious when I read the description "step side pre-runner" but that is probably the coolest single cab I've seen. Very-well executed and it's obvious a lot of love went into it as well. Did you do the 4X4 conversion yourself? I love the rear electrical connector for jumper cables and a stick welder. That's so practical yet so rarely seen, even on high-dollar builds. I also greatly admire that every single modification on your truck has a function and isn't just for looks. I am awed.
  7. Aug 23, 2015 at 6:06 AM
    Ritchie
    Thank you sir... Yes, a lot of love in my rig. I did everything you saw except build the front bumper (Shrockworks).
    My truck is currently 2wd. I purchased the A340F trans, had it rebuilt and added the Inchworm 4.7 Lefty at the same time. I made the shifter and fabbed it so it came up where the OEM shifter would have.
    The Diamond axle and 4WU 3 link are set to go in next weekend.
    Thanks for the reply.
    tacotacolove77 likes this.
  8. Aug 23, 2015 at 7:15 AM
    DJB1
    Dave
    SLC, UT
    allenfab likes this.
  9. Aug 23, 2015 at 1:05 PM
    Ritchie
    Yeah... I have watched his build too. Awesome for sure.
    As I have the auto trans (my wife cannot drive a manual), 5.29's is as low as I can go with Toyota based axles and retain the small amount I have for power with the 2.7 motor running 285-75-16's. My future plans are to incorporate an LS motor when the 3RZ craps out.
    If it weren't a daily driver, I would go richter scale on this thing.
    What all are you doing to your rig?
  10. Aug 23, 2015 at 3:06 PM
    DJB1
    Dave
    SLC, UT
    Right now I'm just building the foundation, I'm only interested in quality mods and I will not be putting any of them on a credit card. I have CBI frame-reinforcement plates in hand, just waiting for a date with the welding machine at my friend Jim's hot rod shop AKA his garage. I have a @BamaToy1997 stage II electrical upgrade on its way, so I'll be ready when the time comes for a winch and extra lighting. I just got an entire non-ADD front axle assembly, so I will be converting to manual hubs including eliminating the ADD axle tube and actuator. Unlike many who convert to manual hubs, though, I will still have functional ABS braking thanks to some excellent info on TTORA. After that, depends on what bargains I find on TacomaWorld and local classifieds.
  11. Aug 23, 2015 at 4:19 PM
    Ritchie
    Nice...
    I am doing the "ABS Delete mod' due to the Diamond axle going in front. Simple to do and better yet, cheap.
    Doing a SAS can get pricey if you're not careful.
    Keep the up-dates coming.
  12. Aug 23, 2015 at 4:22 PM
    Ritchie
    Check Scuba on TTORA. He did a killer job on his regular cab Tacoma. He definitely uses his truck too. View his build... you'll see.
  13. Aug 23, 2015 at 9:06 PM
    DJB1
    Dave
    SLC, UT
    I shall. I am utterly addicted to single cabs.
  14. Aug 23, 2015 at 9:13 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    I'm right there with you guys!! I have two standard cabs! One a DD and the other is built up a bit, nothing fancy.
    ontarioyota likes this.
  15. Aug 23, 2015 at 9:20 PM
    #35
    DJB1
    Dave
    SLC, UT
    I'm already thinking dangerous thoughts, like I'm going to build up "Whitey" but not wheel him too crazy because he's in such good shape, then get a beater single cab, SAS it and wheel the bejesus out of it. Then I'd probably need 2 more single cabs for parts and the next thing I know I'm divorced and living in a single cab Tacoma wondering if my obsession with single cab Tacomas is a bit unhealthy.
  16. Aug 23, 2015 at 11:45 PM
    #36
    bry838
    oregon
    Ahh my big white truck is named whitey too!!! Lol
  17. Sep 28, 2015 at 10:20 PM
    #37
    DJB1
    Dave
    SLC, UT
    Had a fantastic time on Boulder Mountain a few weeks ago. That little red pointy cliff in the bottom left is called Larb Hollow and when you get closer it looks like this:
    Sandy washes are a fucking blast in a Tacoma that's barely bigger than an ATV.
    Sorry, not taking applications for new friends unless you drive a 1st gen single cab.
  18. Sep 28, 2015 at 10:57 PM
    #38
    bry838
    oregon
    Im sending my application!! I have two reg cabs and love utah!! Have even spent a fair bit of time on and around the boulder mt area!
    P.S. I wont wheel with that 5 lug!.....lol. we can use it to keep at the pavement/trail head to run to the parts store if need be.
  19. Sep 29, 2015 at 8:56 AM
    #39
    DJB1
    Dave
    SLC, UT
    Application approved. But I need to submit an application to you since you have two 1st gen single cabs and I only have one.
  20. Sep 29, 2015 at 7:38 PM
    #40
    bry838
    oregon
    Lol
    Btw i love your little truck. My built up rig is white too with black everything that isnt white body panels. Im envious of your '01-'04 style grille/hood though...ive always wanted to do the front end conversion to your style and get rid of my'98-'00 design...
