DJM control arm help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Flippy02, Apr 22, 2020.
  1. Apr 22, 2020 at 6:15 PM
    Flippy02
    Flippy02 [OP] Well-Known Member
    Central Coast, CA
    1999 Black Tacoma Base
    Upgrading with stock options
    I tried calling the tech line, but they're closed for the day. I looked around on the forum and I didn't see an answer.
    The instructions say that the metal sleeves on your control arm should be moving after everything is torqued down.
    I drilled the holes for the bushing and sleeves, greased everything up, torqued it down and when I test it, the bushing moves on the sleeves. What am I doing wrong here?
    Edit: I have to file down the sleeves a few thousandths to fit looser between the shoulder of the mounting arm and washer
  2. Apr 23, 2020 at 12:44 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Pics?
    Never even heard of DJM control arms unless you're on a 5 lug?
  3. Apr 23, 2020 at 12:48 AM
    Flippy02
    Central Coast, CA
