DLAA Brand OEM Fog Light Install, 09 Tacoma
Discussion in 'Lighting' started by BPachom, Oct 2, 2009.
  1. Oct 2, 2009 at 3:21 PM
    BPachom
    BPachom [OP] Well-Known Member
    Long Island
    09 Tacoma SR5, 4cyl 4X4, Black
    Access roll-up tonneau cover, Factory radio W/Sirius, Tailgate clamp, HID head lights, Stainless nerf bars.
    Looking for help.
    I know there are a lot of how to's but did not see one for this OEM style fog light. I purchased DLAA brand (Part #TY227) from http://www.makotoautotrends.com/pro...11181&osCsid=fa5c96829cec5215fda91afc010ea7a2 and the wiring directions just suck.
    The wire harness provided is to be "plug & play" which appears that it would, but the directions do not indicate as to where the power source connections are made. There are plugs/connectors on all ends, as if to plug into a harness connection, fuse box, etc but I do not see similar plugs on the truck.
    Anyone install these before?
    Thanks,
    Bob
  2. Jul 31, 2010 at 3:22 PM
    RichXKU
    RichXKU Active Member
    Rich
    Berks, PA
    '06 reg. cab 4x4 2.7 5MT
    K&N (Previous owner), DIY OEM Cruise, DIY OEM Int. Wipers
    I just got these and I am in the same boat.
    These connectors don't seem to have a home under the dash:
    Did you ever get them installed?
  3. May 11, 2014 at 2:11 PM
    jdjonesiii
    jdjonesiii Member
    Stone Mountain, Georgia
    2014 2.7L 4x4 5 Speed
    new shift knob, intemitten windshield wiper assembly added for lights changed transmission fluid to Redline MT-90.
    Toyota fog light kit has everything. install in about 3 hours.
    Gentlemen stop suffering with your fog light problems. Toyora Factory fog light kit with everything. I purchased and installed in about 3 hours. Plug and play. Link also has install instructions. Discounted price from this dealer. http://toyota-of-mcdonough-parts-2.t...light-kit-2012 John Stone Mountain Georgia
    Guys you have to get to the wiring color codes with a good light to see. The color coding is exactly like the install instructions. However, you do have to find the correct ones in the harness. I read the instructions many times. Use T Tap Connectors so you do not have to splice wires.
