DMH Exhaust cutout
Discussion in 'Technical Chat' started by Tukohmah, Sep 10, 2006.
  1. Aug 10, 2012 at 12:46 PM
    UNDEAD1153
    UNDEAD1153 Well-Known Member
    Weston
    Chattanooga Tennessee
    White 2011 TX Pro Double Cab
    Rough Country 6" lift, 17" XD Addicts, 315/70/17 Nitto Trail Grapplers, 6K HID's, Wet Okole's, Kenwood DD head unit, Custom Exhaust
    Thanks man! I believe the switch only has 2 wire (red and black, the red containing a fuse) the switch has a 3rd wire but all it does is connect to the cutout. How do I wire it to the cigarette lighter or 2 the battery with only 2 wires to wire from?
  2. Aug 10, 2012 at 1:01 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You refer to 2 things as the switch, I'm not sure what you're referring to.
    You'd have to either find the cigarette lighter fuse or tap the power to the cigarette lighter behind the dash for your trigger wire. If you use the fuse, use an Add-a-circuit to draw power to trigger your relay. If you go directly to the wire, splice the wire, solder and heat shrink the connection to power the relay trigger.
    If something only has 2 wires, one is hot (the one with the fuse), the other is a ground.
    Check out the attachment, it should help out a bit.
