DMM and wire routing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoMV, Nov 8, 2020.
  1. Nov 12, 2020 at 4:30 PM
    TacoMV
    TacoMV [OP] Well-Known Member
    Michael
    2021 TRD Off Road DCLB Voodoo Blue
    Cool. Thanks. For some reason, I recall seeing that the cig charger outlet was a lower amp rating - I may have that wrong. But I assume you just tied in to the power from the old socket when you put the new one in?
  2. Nov 12, 2020 at 5:11 PM
    MNlaw
    MNlaw @Overland_Minnesota
    2019 Quicksand TRD Off-road DCSB
    woo I have had the DMM for over a year now and never thought about running the wire behind...may just have to do that
    TacoMV[OP] likes this.
  3. Nov 12, 2020 at 5:29 PM
    scrubdug
    scrubdug Active Member
    doug
    Atl
    14 tacoma trd sport/previous 19 trd or
    na
    do you guys have a usb outlet in your center console under the lid? I ran a 6' charging cable from there through the console and up through the dash and out to the dmm to my phone holder.
  4. Nov 12, 2020 at 5:33 PM
    MNlaw
    not a bad idea but I prefer playing music directly off my phone but that would require using bluetooth instead
  5. Nov 12, 2020 at 7:17 PM
    TacoMV
    Michael
    It was super easy - head unit is four 10mm bolts - slides right out abs lots of room to get your hand behind it to fish for wires.
  6. Nov 12, 2020 at 7:18 PM
    TacoMV
    Michael
    I just used the one in the front of the dash because it works with CarPlay.
  7. Nov 13, 2020 at 7:34 AM
    CortezJB
    CortezJB Well-Known Member
    Juan
    San Francisco
    2017 Tacoma TRD Sport
    NADA
    Correct again!!
    that is what I did.
    TacoMV[QUOTED][OP] likes this.
  8. Nov 13, 2020 at 8:32 AM
    TacoMV
    Michael
    So out of curiosity - why is the cig socket so much lower in amperage - I would assume that since you use the same power wires, the same limitation would be there? Or is there something about the socket itself that's the limiting factor?
  9. Nov 13, 2020 at 10:01 AM
    CortezJB
    Juan
    San Francisco
    NADA
    Yea it is true!! but that is the one that I had in hand. I will replace it, however, once I find some time to work on it. I want a quick charge for sure.
  10. Nov 13, 2020 at 10:03 AM
    TacoMV
    Michael
    Ah - okay - so 2.5 isn't really 2.5.
  11. Nov 13, 2020 at 10:07 AM
    CortezJB
    Juan
    San Francisco
    NADA
  12. Nov 13, 2020 at 12:15 PM
    FreshMexicanTaco
    FreshMexicanTaco The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    This is what I did on my truck as well for power up top,
    The standard USB is on the same module as the AUX jack so I connected both and routed them up to the top where they are always connected to my DMM mounted ipad
    GoldenTaco27 and TacoMV[OP] like this.
  13. Apr 17, 2021 at 10:14 AM
    TacoBucc11
    TacoBucc11 Member
    Connecticut
    2021 TRD Off Road gray metallic
    looks like you did a lot of research on this! I’m on the same page with you about having access to CarPlay and allowing someone else to plug into it if they wanted. Wondering if you saw any other options? I might take your lead on doing similar mod
  14. Apr 17, 2021 at 10:41 AM
    TacoMV
    Michael
    I’m sure there are other options out there....this one felt like the best route to me. The DMM and Ram mounts are really solid and I’ve had zero issues since I did the install.
