DMZ 2006 Tacoma Long Travel Suspension Build
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Single6, Nov 10, 2010.
  1. Nov 10, 2010 at 5:25 PM
    Single6
    Single6 [OP] Active Member
    Pacific Palisades, California
    2006 Tacoma 4x4 Front & Rear Long-Travel
    DMZ Custom Build - Front: Total Chaos Long-Travel (13.5") Suspension, TC Extended Axles, Reinforced Spindles & Alignment Cam Tabs, Limit Straps, SS Brake Lines, TC Specification 8x2.5 King Coilovers/Springs, Secondary Gusseted Shock Hoops, TC Specification 8x2.5 King 3-Tube Bypass Remote Reservoir Shocks, Reinforced Motor Mounts, Pre-Runner Bumper & Front/Under-Engine Skid Plates, SS Radiator Guards, Aux. Lighting/Breaker Panel/Wiring, VisionX HID 8.7" Round 50w. Lamps, VisionX Reflex 9" LEDs, OEM HID Headlight Conversion, Glassworks Fiberglass Fenders, DMZ Stealth Antenna, DMZ Custom Build - Rear: Custom Spring-Under Conversion & Perimeter Bed/Shock Cage (16" travel), DMZ Spec. Deaver LT Springs, Plated & Boxed Rear Frame, King 16x2.5 4-Tube Piggy-Back Reservoir Bypass Shocks, 2x2 King Bump Stops, Bed Shock Shields, Limit Straps, SS Brake Lines, Glassworks Fiberglass Bedsides, Aluminum Billet Wheel Spacers, Allied 16x8 Forged Monster Wheels, OMF Beadlock Conversion, Integrated TPMS
    FYI: For 2nd Generation Tacoma owners considering a Long-Travel Build/Conversion
    I spent close to a year researching every build and equipment permutation for a front and rear Long-Travel (LT) Conversion of my 2006 Tacoma Double-Cab 4x4. Yes, I spent many hours on the internet, and investigated, contacted or visited virtually every manufacturer and fabricator in Southern California that offered and/or installed LT suspension systems for my Tacoma. Why all the effort? Because I imposed several key constraints/requirements on the build, and was also concerned that I might be underwhelmed or even disappointed by the performance of the LT conversion after spending so much time and money. I have considerable experience driving and riding off-road. One could say, I appreciate a balanced and effective suspension system, not only for speed, but for safety and control. The choices are more complicated than they first appear.
    I finally pulled the trigger in early summer and have tested the truck on a variety of off-road trips since then. The details of the build can be referenced on my TacomaWorld profile - Username: Single6
    The considerable fabrication work for the front and rear LT build was performed by Tim Duncan at DMZ in Norco, CA. using primarily a Total Chaos front suspension package, King shocks, and a DMZ custom perimeter bedcage with a spring-under conversion. Tim (owner) spent hours patiently answering my questions, which covered much more than just suspension, and offered invaluable recommendations and advice on trade-offs, as did the people at Total Chaos, King, Deaver, OMF and VisionX. But Tim really pulled-it together. During the build, Tim creatively solved several problems we confronted, and executed the work as if it was his own vehicle.
    The results far exceeded my expectations in terms of design, build quality, and both on and off-road performance. I attended a King shock tunng session in Barstow to properly adjust the valving on the bypass shocks soon after the build's completion. A few adjustments from Iribe, the shock tuning specialist, produced marked improvement in ride, speed and control. The bottom line is my Tacoma, after the suspension work and reinforcements, is a vehicle capable of off-road speeds not prudent without a full racing cage. Off-road, the ride improves as the speed increases. Notwithstanding, the ride is equally improved on very rocky, slow patches, for example narrow, old, very rutted mining roads where one has no choice but to go slow in low range. On-highway performance and around town ride is also substantially better - my wife even noticed an improvement.
    The reason I drafted this thread was primarily to reward good, knowledgable, and helpful people in the industry who are designing, fabricating, and installing quality equipment. Among those people are primarily Tim at DMZ Fabrication & Race Prep, Pat at Total Chaos Suspension, Brian & Iribe at King Shock Technology, Jeff at Deaver Spring, Tim & Bones at OMF Beadlock Wheel Conversions, Joe & Rick at VisionX Off Road Lighting, and the folks at GlassWorks and Allied Wheel. In addition, this may help some Tacoma owners that may be considering Long Travel suspension conversions.
    Regards,
    Single6
  2. Nov 10, 2010 at 5:56 PM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    New York-not the City
    Indigo SR5 4x4
    You California guys get to have all the (offroad) fun. Sounds like a great set up. If you have any pictures, it would be great to see.
  3. Nov 10, 2010 at 6:09 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  4. Nov 10, 2010 at 7:33 PM
    Single6
    I'll try to post some images when I get a moment free.
  5. Nov 10, 2010 at 7:37 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Tease. I was expecting pictures
  6. Nov 11, 2010 at 9:30 AM
    Single6
    Here are a few images:
  7. Nov 11, 2010 at 9:39 AM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    Cool, Full truck pics please:)
  8. Nov 11, 2010 at 9:52 AM
    Sabre
    Sabre Well-Known Member
    Kyle
    Silverdale, WA
    2014 F-150 FX4
    ^^what he said
  9. Nov 11, 2010 at 9:57 AM
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    that skid thats covering the rear bypassed are fucking sic.... thats what would always worry me... if ya loading up some shit in the truck.... and u hit a bypass... that would realllyyy suck haha but yea full pics of the truck please !!!
  10. Nov 11, 2010 at 10:03 AM
    sandman427
    sandman427 KR FAB
    Amir
    BAMF TACO!!
    for OP do u have a locker and is it still useable..???
  11. Nov 11, 2010 at 10:17 AM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    yah dmz is a great shop!! i had tim reinforce my cam tabs and he was totally chill with great customer service! pretty soon im gonna have him add a shock hoop and 2.0 bypass for me and hopefully later lt my rear
  12. Nov 11, 2010 at 10:18 AM
    8th sin
    8th sin Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    were these pictures taken with a film camera? lol nice rig though, we need more pics! film or otherwise
  13. Nov 11, 2010 at 10:32 AM
    Sabre
    Kyle
    Silverdale, WA
    2014 F-150 FX4
    dont tease us like this!!!! we demand pics!!
  14. Nov 11, 2010 at 10:35 AM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Truck looks amazing. I spoke with Tim this week about a brake issue and he told me about your truck.
    DMZ consistently puts out the best work on any build I have ever seen.
    For those of you on the W.Coast who look to save a few pennies by going with other shops look at the quality and see what your missing!
  15. Nov 11, 2010 at 10:37 AM
    Single6
    Sorry, no spare locker.
  16. Nov 11, 2010 at 10:51 AM
    cummins6speed
    What makes you think they were taken with film?
  17. Nov 11, 2010 at 10:54 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    i love the bed light mod. Pics of the entire truck please, looks sick from what i can see
  18. Nov 11, 2010 at 10:57 AM
    chyknees
    chyknees nomadic wanderer
    So Cal
    05 Tacoma TRD 4x4
    TRD, Total Chaos, Fox, Volk, BFHoodrich
    wow....sick job on the suspension, especially the rear bed cage. More full pics!
  19. Nov 11, 2010 at 11:03 AM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    Indigo SR5 4x4
    Damn I want the know how to do this. But then again there is really no where I could go jump my truck.
  20. Nov 11, 2010 at 11:18 AM
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    KINGS SUSPENSION & TOTAL CHAOS. . . . .
    NUFF SEDDD. No need for further pics..Already BAD ASS!
