DMZ 2006 Tacoma Long Travel Suspension Build
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Single6, Nov 10, 2010.
  1. Nov 12, 2010 at 11:06 AM
    #41
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
  2. Nov 12, 2010 at 11:37 AM
    #42
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    Wow OP, very impressive that you took the time (TIME) to RESEARCH all options. Calling, talking, and no doubt previous off road experience is what brought you to this point. I can relate in many ways, and hopefully will be able to fund a similar high dollar project in the future. Thankfully I've had the opportunity to ride in a properly set up LT truck, and then a poorly set up TC LT on an old Nissan. It really does come down to valving... glad to hear DMZ was a success in your case. Congrats and enjoy!! I'm a step behind you, but one day will get to this point.
  3. Dec 1, 2010 at 12:50 PM
    #43
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    What is the next step in this build? Supercharger, Currie 9", roll cage? I am really excited to see what you have Tim to do this truck next.
  4. Dec 1, 2010 at 12:57 PM
    #44
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    That bed cage is fuckin' awesome!
  5. Dec 1, 2010 at 6:13 PM
    #45
    08WhiteTRD
    08WhiteTRD Well-Known Member
    Ben
    Rocklin, NorCal
    2008 White 4x4 TRD Sport
    Fox Suspension 2.5 Front and 2.0 Rear, All-Pro Skids, BAMF LCA Skid, Leer 100R, Scangauge II, WeatherTech Floorliners, WeatherTech window visors, Satoshi grill with HomerTaco mesh, Sockmonkey Tailgate Decal, BHLM, Center Console lock, ImMrYo Rear-view bracket, Rally Armor mud flaps, Crawford Eco-Block, USA-Spec PA-15
    That is one sick looking truck. If/when I get LT I want a bed cage like that.
  6. Dec 1, 2010 at 7:07 PM
    #46
    Single6
    Single6 [OP] Active Member
    Pacific Palisades, California
    2006 Tacoma 4x4 Front & Rear Long-Travel
    DMZ Custom Build - Front: Total Chaos Long-Travel (13.5") Suspension, TC Extended Axles, Reinforced Spindles & Alignment Cam Tabs, Limit Straps, SS Brake Lines, TC Specification 8x2.5 King Coilovers/Springs, Secondary Gusseted Shock Hoops, TC Specification 8x2.5 King 3-Tube Bypass Remote Reservoir Shocks, Reinforced Motor Mounts, Pre-Runner Bumper & Front/Under-Engine Skid Plates, SS Radiator Guards, Aux. Lighting/Breaker Panel/Wiring, VisionX HID 8.7" Round 50w. Lamps, VisionX Reflex 9" LEDs, OEM HID Headlight Conversion, Glassworks Fiberglass Fenders, DMZ Stealth Antenna, DMZ Custom Build - Rear: Custom Spring-Under Conversion & Perimeter Bed/Shock Cage (16" travel), DMZ Spec. Deaver LT Springs, Plated & Boxed Rear Frame, King 16x2.5 4-Tube Piggy-Back Reservoir Bypass Shocks, 2x2 King Bump Stops, Bed Shock Shields, Limit Straps, SS Brake Lines, Glassworks Fiberglass Bedsides, Aluminum Billet Wheel Spacers, Allied 16x8 Forged Monster Wheels, OMF Beadlock Conversion, Integrated TPMS
    Tim at DMZ in Norco, CA is the only guy that does it. He know his stuff!
    I do a lot of camping and this bed is the ticket.
    Regards,
  7. Dec 2, 2010 at 3:57 PM
    #47
    Single6
    BTW, I looked into superchargers/blowers, but the gas consumption is quite high. Obviously, this reduces the driving range of the truck - not good when camping deep in the backcountry. Unless evidence convinces me otherwise, I will not be putting a supercharger on it. It's a pity because I would love to have a supercharger when driving at higher elevations. Unless something breaks, I think I'm done except for a tire change when these are worn. It should have a roll cage, given the off-road speeds it's capable of, but I will not be racing it. Hopefully, I'm mature enough to not drive beyond my abilities, and maintain a margin of error.
    Regards,
  8. Dec 2, 2010 at 4:30 PM
    #48
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I would love to disprove this, in my findings verses a stock truck if you are able to keep the rpms under 2.5k with the sc and instead of downshifting it uses boost to maintain/increase your speed my gas mileage increased. It makes it quite reasonable as a daily driver, and once the novelty of the supercharger wore off now I can get better gas mileage than stock. In the desert this may not be the case but these are at least my findings.
  9. Aug 11, 2011 at 12:20 PM
    #49
    TACOMA TIME
    TACOMA TIME Member
    Pasadena
    4x4 Total Chaos Custom Long Travel
    Kings 2.5” Coil over and Kings Triple bypass, Deaver rear leaf springs, a whole bunch of stuff.
    Very sic, nice coating on the back cage.
  10. Nov 5, 2011 at 6:41 PM
    #50
    JAG
    JAG Well-Known Member
    subbed so i can find it again!
    thanks
    awesome truck
  11. Nov 6, 2011 at 9:38 PM
    #51
    TACOMA TIME
    TACOMA TIME Member
    Pasadena
    While we're at it, the team over at Performance Motorsports in Las Vegas did mine well too. Their support and patience were rocking.
    In re: the tuning sessions near LA or Barstow are of interest. It'd be nice to have some more advise and expertise with tuning the shocks in. I'll look for the next Kings meeting.
    Thx
  12. Nov 6, 2011 at 9:56 PM
    #52
    screename
    screename Well-Known Member
    Van
    Houston, TX
    He said "It was not inexpensive". The "not" and the "in" cancel each out so basically he is saying..... It was expensive.
  13. Nov 13, 2011 at 4:02 PM
    #53
    T A C O M A
    T A C O M A Well-Known Member
    How much did all the parts and instalation cost together?
  14. Nov 13, 2011 at 4:50 PM
    #54
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    I can see a ballpark estimate of around 15-20k. Labor and parts. Those king shocks are not cheap and neither is fabrication work.
  15. Nov 13, 2011 at 5:19 PM
    #55
    T A C O M A
    I wonder how many hours went in to fully install the LT suspension
  16. Nov 13, 2011 at 5:27 PM
    #56
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
  17. Sep 25, 2012 at 7:12 AM
    #57
    mk7
    mk7 Well-Known Member
    Michael
    Austin, TX
    '11 4x4 TRD Off Road
    Awesome build.
  18. Sep 25, 2012 at 7:48 AM
    #58
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
    great build... it's clear no corners were cut. as far as the supercharger... you would most likely see an increase in MPG's if you keep your foot out of it. the motor only has to work half as hard when building boost from 100rpm's.
  19. Sep 25, 2012 at 8:15 AM
    #59
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    looks like good work. I really like how you left the bed functional and the cage and shocks only minimally invade the cargo space.
