do 08 have batteries in tire pressure sensor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LEEP, Nov 9, 2010.
  1. Nov 9, 2010 at 11:40 AM
    LEEP
    LEEP [OP] Well-Known Member
    LEE
    CONNECTICUT
    O8 TACOMA TRD
    hear they do anyone change them
  2. Nov 9, 2010 at 12:03 PM
    LEEP
    LEE
    CONNECTICUT
    O8 TACOMA TRD
    parts dept at dealer said no batteries just called them
  3. Nov 9, 2010 at 12:25 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Taken off the Toyota TPMS website:
    TPMS replacement is called for when the TPMS fails due to mechanical or electrical failure, broken accelerometer, low TPMS battery power or blocked pressure port. One of the most common causes of failure is inappropriate handling during wheel or tire removal or servicing. The TPMS is an electronic component fitted as part of a heavyweight mechanical process.
    I read somewhere that said the average life of the batteries is around 10 years.
