Do 1"-3" lift coilovers need new UCA's?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KyleJP, Dec 9, 2014.
  1. Dec 9, 2014 at 10:26 PM
    KyleJP
    KyleJP [OP] Member
    Kyle
    Montana
    14 base 4x4
    If I put 1"-3" lift coilovers on my truck, are aftermarket UCA's necessary, or will stock ones work? Also maybe some pros and cons with running stock or aftermarket
  2. Dec 9, 2014 at 10:31 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    if not for wheeling/wheel travel, people generally get aftermarket uca's if lifting their trucks throws out their alignment, causing vibrations at speed
    usually, people don't get vibrations until they lift more than 2", then aftermarket UCA's are needed for additional caster, which gets rid of the vibes.
    but "need" is pretty subjective in the 1-3" range. People run stock arms and just deal with the vibes, some people can't stand the vibes
    but if you have the $ for aftermarket, grab the UCA's so you don't have to worry
  3. Dec 9, 2014 at 10:38 PM
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    Was running 5100 at 2.50 with stock uca got the Alignment all green now I'm running Fox C/O EX Travel at 3" with TC uca and its way better usually anything over 3"you will need UCA
  4. Dec 9, 2014 at 10:40 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    with stock UCA and 2.5-3" lift, you will have very little castor. your steering will be subject to 'bump' steer, meaning that
    a) you will notice you have to turn or pull your steering wheel to get your front wheels back to center,
    b) larger bumps or potholes will pull your steering direction easily.
    Its noticeable, but certainly not dangerous or unpleasant to drive.
  5. Apr 3, 2015 at 11:05 AM
    odn
    odn Member
    destin
    4x4 blk
    I did 3" with the toytec ultimate lift kit with stock uca.
    I literally felt no difference. Driving was great and normal as before.
  6. Apr 3, 2015 at 11:15 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    an aftermarket UCA will NOT cure vibrations caused by the needle bearing in the front diff.
