Do 16’s fit on the 24’ Tacoma?
Discussion in '4th Gen. Tacomas (2024+)' started by radclerk1, Dec 24, 2024.
  1. Dec 24, 2024 at 7:52 AM
    radclerk1
    radclerk1 [OP] Well-Known Member
    Vic
    2017 Access Cab 2.7L Manual 4x4
    None
    Any pics of 16’s ?
  2. Dec 24, 2024 at 8:17 AM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    No they don't fit unless you remove the brakes.
    LN13 and Steves104x4 like this.
  3. Dec 24, 2024 at 8:23 AM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    3JOH22A and radclerk1[OP] like this.
  4. Dec 24, 2024 at 10:13 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
  5. Dec 24, 2024 at 10:15 AM
    Bishop84
    Bishop84 Well-Known Member
    Like a rally car fitting 15" lol
    Massive spacers or offset doesnt count as "fitting"
    The oem 16" from 3rd gen likely doesnt fit, thats the real metric.
    batacoma[QUOTED] likes this.
  6. Dec 24, 2024 at 10:20 AM
    TAZMINATOR
    2017 Tacoma
    OP on Reddit said 0 offset in his thread. Go back to the site and read.
  7. Dec 24, 2024 at 2:43 PM
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    Just - Why???
    Sagebrush likes this.
  8. Dec 24, 2024 at 4:06 PM
    batacoma
    batacoma Truck Wars
    0 is on the aggressive side for the 4G. It's not a -38 or more which is usually considered aggressive for a 6 lug tacoma. I like 16" wheels and would like to see them easily fit the 4G, I just didn't think it could happen after seeing the 17" steel wheels on the SR. I don't know what's out there that works or won't work.
  9. Dec 24, 2024 at 4:19 PM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
  10. Dec 24, 2024 at 9:36 PM
    Bent Wheel
    Bent Wheel Well-Known Member
    Big Phat 2021 Tundra
    damaged underside
    Less wheel. More rubber?
    BearWithMe and CrispyTacoLover like this.
  11. Dec 25, 2024 at 5:17 AM
    TAZMINATOR
    2017 Tacoma
    There are many sizes you choose from, such as offset, spokes patterns, lug pattern, etc.. I know people want 16" wheels for off roading. I have 17" on mine which they are fine for off roading.
    You have to remember '24 models are kinda new for a year. I am sure wheel factories are making more for '24 models and newer so they will fit no matter what model trim you have.
  12. Dec 25, 2024 at 6:47 AM
    batacoma
    batacoma Truck Wars
    I don't think anybody is putting 16" wheels on the hybrid as it leaves the factory 18" wheels the brakes are supposedly larger up front.
    The smallest diameter wheel people are fitting on the Tundra are 17" no idea what if anything the Tundra and Tacoma share in brake components.
    I didn't want to see the large PDC hub go away from the previous truck. Toyota didn't even stay consistent with Ford on the size of the new hub, which is 106.something and the Ranger is 104.something no idea what size bore GM is using. I guess you build the wheel to fit an axle and not the other way around.
  13. Dec 25, 2024 at 7:22 AM
    TAZMINATOR
    2017 Tacoma
    If you want 16" and they don't fit on newer Tacoma, then stick with your 2nd gen. Or change everything under the new Tacoma, I mean axles, brakes, etc..
    If it was me, I am not taking hybrid Tacoma to the trails, I take my '17 to off road park. Hybrid for street uses.
  14. Dec 25, 2024 at 7:28 AM
    batacoma
    batacoma Truck Wars
    I'd just use the wheels that are already on the 4G if I had one. The thread specifically asks about fitting 16" wheels on the 4G. I still say they don't fit.
  15. Dec 25, 2024 at 5:01 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    4th gens are available with two brake sizes. The non-OR gasser trims have 320mm rotors similar to 3rd gen, so 16" wheels can be expected to fit. The hybrids and OR gasser trims have 340mm rotors similar to 5th gen 4Runners, so 17" wheels are minimum.
