Do 16" Wheels from 01 Fit on a 99?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jeeters79, May 8, 2009.
  1. May 8, 2009 at 3:54 PM
    jeeters79
    jeeters79 [OP] Active Member
    Stanwood, WA
    '99 4X4 SR5
    I've got a 99 4x4 Tacoma and a bit of a problem... I've always had a "shimmy" on the freeway with my current set of tires. Before I had some very aggresive mud tread and assumed that it was the cause. After they came off I noticed the vibration and thought it was bad balancing. Three trips thru and finally someone has the decency to tell me that one of my wheels is bent. So now I'm looking around and have found a decent deal on some 16" wheels off an '01 Tacoma. I know that the middle cap on the wheel will have to get popped out on my fronts so my hub locks will clear, but otherwise this should work? Or is there not sufficient clearance for the hubs? I like the look of these stockers much more than the 15"s from my own year, and the price is right.(NOTE: Money is tight but I hate the shaking...!) Anybody know about this? Thanks!
  2. May 9, 2009 at 3:23 AM
    jeeters79
    Stanwood, WA
    '99 4X4 SR5
    Has anyone done this? Or maybe I'm not seeing anything on the site concerning this for a reason.... hmmm.
    Seriously? Where do I find this out?
  3. May 9, 2009 at 8:42 PM
    Quagmire
    Quagmire Member
    Well I'm new here but no stranger to car forums, but if you knew the offsets of the wheels you can figure out if you have enough clearance. Also maybe a picture of the wheels.
    Hope I could help and good luck!
    Giggity! :D
    Code:
  4. May 9, 2009 at 9:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Yes, they will fit.
  5. May 9, 2009 at 9:51 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    They will fit, but the tires will rub on the front mud flaps at full turn when going over speed bumps etc. But this happened when I got new tires, didn't rub when the tires wore a little.
  6. May 9, 2009 at 11:16 PM
    jeeters79
    Stanwood, WA
    '99 4X4 SR5
    Let me re-state my biggest worry - I have manual locking hubs, not the auto locking ones everybody else gets now. The center of my existing wheels pop out so the hubs are accessable on the front. What I need to know is will the later Tacoma wheels centercap pop out cleanly so I can get to my hubs?
    fyi here's the ad for the wheels with pics
    http://skagit.craigslist.org/pts/1155567048.html
  7. May 9, 2009 at 11:19 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    that center cap is easy as crap to take off
    no problem
  8. May 9, 2009 at 11:22 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    that truck is an 02...but converted to manual hubs...they fit fine with those wheels...but im not entirely sure if the center caps still fit in the front...he never puts them on anyways
  9. May 9, 2009 at 11:27 PM
    jeeters79
    Stanwood, WA
    '99 4X4 SR5
    HALLELUJA!!!!! Finally some pics! Ok, they will fit. Thanks Tigerfan00!
  10. May 10, 2009 at 5:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I cut the center of some centercaps to fit my manual hubs......Use a dremmel or the like.
