Do 2015 Tacomas come with wiring harness for fog lights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mason502, Dec 2, 2019.
  1. Dec 2, 2019 at 9:25 AM
    Mason502
    Mason502 [OP] Well-Known Member
    Mason
    Mount Sterling, Kentucky
    2015 Tacoma 4x4 Access Cab 2.7 Automatic
    Bilstein 5100 shocks, cali raised LED.
    I’m wanting to install fog light to my truck and just wondering if it’s pre installed with the wiring harness. Anyone with a 2014 or 2015 please let me know
  2. Dec 2, 2019 at 9:49 AM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    I'm going to guess yes, since Toyota tends to use the same harness across trim levels. I'd have a look under the truck and see.
  3. Dec 2, 2019 at 9:53 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    I have a 2014 and can confirm that a pre installed wiring harness does exist. Good Luck...what make of fog lights are you installing or are you going OEM?
    JC15Taco likes this.
  4. Dec 2, 2019 at 10:02 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    No 2.7 trucks are pre wired. All V6 trucks are.
    The harness/fog light kit for 2nd gens is discontinued. Not sure if 3rd gen is compatible.
  5. Dec 2, 2019 at 10:05 AM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    It's too bad...hadn't considered the motor difference.
  6. Dec 2, 2019 at 10:11 AM
    T4RFTMFW
    For reference the last known PN I had for the install kit was 00016-35220 for the OEM kit.
    You can buy aftermarket fog light kits that come with a harness, so you aren’t SOL by any means. But, you’ll need a harness, relay, switch, fog assemblies. Third gen fog lights will fit.
  7. Dec 2, 2019 at 10:29 AM
    Mason502
    Mason
    Alright guys thanks for the help
  8. Dec 2, 2019 at 10:40 AM
    T4RFTMFW
