Do 2TRs have a high pressure fuel pump?
Discussion in '4 Cylinder' started by NewMexiMan, Oct 17, 2020.
  1. Oct 17, 2020 at 3:29 PM
    NewMexiMan
    NewMexiMan [OP] Well-Known Member
    2016 SR 5 Speed
    From what I see it's only in the 2GR. But if not, then what's that weird fluttering/flapping/chirping noise I hear when I cross into the promised land above 4k RPMs?
  2. Oct 17, 2020 at 3:36 PM
    Bishop84
    Bishop84 Well-Known Member
    No. They are standard EFI with a 44psi pump.
  3. Oct 17, 2020 at 3:58 PM
    NewMexiMan
    2016 SR 5 Speed
    Thanks. So what's that sound I hear? Is that just the sound that's made by the 150ish tiny horses that live inside my engine?
  4. Oct 17, 2020 at 4:53 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    HPFPs are only on direct injection engines, which the 2TR isn't.
    The only thing I can think of is maybe it's tied to the variable valve timing. I've never noticed anything like you're describing in my 08 with the 2TR. The 3rd gen is dual VVT, so it could be the exhaust valve timing changing.
  5. Oct 17, 2020 at 6:34 PM
    NewMexiMan
    2016 SR 5 Speed
    Hmm, thanks buyobuyo. Anybody else hear what I'm hearing?
  6. Oct 20, 2020 at 8:55 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I have heard something similar on mine. Mainly when on the highway and i go from coasting to tipping back into the throttle. I have always wondered what it was, but kinda thought it might be VVTI related. Sounds like it has something to do with vacuum though
  7. Oct 20, 2020 at 1:34 PM
    NewMexiMan
    2016 SR 5 Speed
    Vacuum? Say more.
