Do 3rd gens have a shorter shock length on the drivers side?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FloridaCementTaco, Mar 28, 2022.
  1. Mar 28, 2022 at 1:05 PM
    FloridaCementTaco
    FloridaCementTaco [OP] Well-Known Member
    OEM running boards OEM bed lights OEM all-weather mats OEM chrome exhaust tip Gator soft, tri-fold tonneau cover 265/75/16 BFG KO2s Removed “chin strap” AC drain extension Rear differential breather extension Bilstein 5100 rear shocks Bilstein 5100 front height-adjustable shocks set at second height OEM tailgate remote lock
    Today, I installed 2 rear Bilstein 5100s on my 2021 Tacoma. After install, I measured from the top of the frame mount to the bottom of the shocks and noticed the passenger’s side shock is about 1” more extended than the driver’s side shock. But the truck is level side to side. Is this normal because the driver’s side shock is mounted behind the axle while the passenger’s side shock is mounted in front of the axle?
  2. Mar 28, 2022 at 1:49 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I don't know what you are asking. Shocks have nothing to do with the "level-ness" of your truck. Springs are what controls the distance to ground of your truck. Shocks are a fixed length same length on the back of the Tacoma. :notsure:
    WELLSPRING, Chew, eurowner and 3 others like this.
  3. Mar 28, 2022 at 1:54 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    I think he's referring to the infamous "Taco Lean".
  4. Mar 28, 2022 at 1:55 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I think what he is saying is that when mounted, both shocks are a different length. Pretty much he is trying to figure out if the distance from the left mount to the axle is the same as the right mount to the axle.
  5. Mar 28, 2022 at 3:11 PM
    FloridaCementTaco
    I’m saying the space between the top and bottom shock mount is shorter (by about 3/4”) on the driver’s side vs the passenger’s side. But the height of the truck doesn’t measure lower on the drivers side. The shocks fit, but on the drivers side the shock is less extended because of the shorter distance between the top and bottom mounts. Wondering if that’s normal or if my truck is screwed up. Maybe someone can measure theirs to see.
    hiPSI[QUOTED] likes this.
  6. Mar 28, 2022 at 3:11 PM
    FloridaCementTaco
    Correct
    5nahalf[QUOTED] likes this.
  7. Mar 28, 2022 at 3:32 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I've never measured them, but I'm skeptical distance from the shock mount to the axle is asymmetric. Are you sure the truck is level? Post your measurements and how you measured them.
    Yes it is normal for the driver’s side shock to be mounted behind the axle while the passenger’s side shock is mounted in front of the axle. I'm not sure why that is the case, but it is the case on my truck and every other one I've looked at.
  8. Mar 28, 2022 at 3:49 PM
    manwithtools
    manwithtools Well-Known Member
    Dan
    So Cal - San Diego
    2021 Cement Gray Off Road
    Fox 2.5's Deaver Stage 2. 5.29's, 285/70/R17 Front E-Locker
    The mounting of shocks on opposite sides of the axle is done to prevent axle "wrap" under acceleration / deceleration. It's been done that way for decades on leaf spring vehicles of varying types.
  9. Mar 28, 2022 at 4:01 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Learned something new. I've known they were that way, but never looked into why.
    Road_Warrior likes this.
  10. Mar 28, 2022 at 4:15 PM
    FloridaCementTaco
    Measured from top of frame mount to bottom of axle mount. Also measured from inside of frame mount to bottom of axle mount. Definitely 3/4” shorter on drivers side. Enough that I can notice the rubber boot on the drivers side shock is looser than the one on the passenger’s side. The new shocks can’t be the issue since shocks done directly impact height. It’s probably been like that and I only noticed because I changed the shocks.
  11. Mar 28, 2022 at 4:19 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    OP…I have a set of OEM Bilsteins in my basement that came off a 3rd Gen OR. Haven’t put them on my SR5 yet.
    They’re the same length, well front and front/rear and rear are the same…you get the idea.
  12. Mar 28, 2022 at 4:25 PM
    manwithtools
    Dan
    So Cal - San Diego
    You folks that panic and think your truck is in someway different from others need to spend a week or two in an automotive manufacturing plant. There is simply no way for a frame or axle or shock mount to be miss located by 3/4". It's just impossible given the jigs, fixtures, robots and tooling that are used during manufacturing and assembly.
    I'm not saying that the distance between mounts is not different. I'm saying if the distance between mounts is different, then it's designed that way. As long as the shock does not reach full extension or compression during suspension cycling, the shock length is not a factor. Both shocks can be the same effective length and work in either location.
  13. Mar 28, 2022 at 4:33 PM
    gudujarlson
    Minnesota
    Ok, but what about the hub to fender measurements? How do you know the truck is level? It's typical for a taco lean to the drivers side. My passenger side rear is about 0.5" higher than my driver side rear.
  14. Mar 28, 2022 at 4:34 PM
    5nahalf
    Erik
    Minnesota
    Y'all are missing his question with other things he never said.
    Lets start from the top.
    His truck is level
    His truck is fine
    He has no issues with the truck
    He wants to know if when installed, one shock should be longer than the other as a result of the different mounting locations.
  15. Mar 28, 2022 at 4:38 PM
    FloridaCementTaco
    Yes thanks for clarifying
  16. Mar 29, 2022 at 6:43 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I would think if the truck is not sitting on a level surface side to side, the shocks are going to measure different.
  17. Mar 29, 2022 at 8:37 AM
    FloridaCementTaco
    Update - I measured from frame to top of leaf springs (next to U bolts) on each side. The drivers side spring is about 1/2” closer to the frame. That’s about the difference in the shocks with a 1/2 tank of fuel. Any ideas?
  18. Mar 29, 2022 at 8:43 AM
    zoo truck
    None
    Its likely the weight of 1/2 tank of fuel is causing the spring to collapse some?
  19. Mar 29, 2022 at 8:51 AM
    FloridaCementTaco
    Must be related because when it was full the difference was 3/4” and now it’s 1/2”. Still seems like a lot but maybe I’m expecting better tolerances than Toyota can actually deliver.
  20. Mar 29, 2022 at 9:17 AM
    gudujarlson
    Minnesota
    That's normal and is referred to as "taco lean". I don't think its a manufacturing defect but rather a design feature or mis-feature. In the end, it is nothing to worry about.
