Do 4runner front seats fit into a Taco?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bridge4, Feb 6, 2018.
  1. Feb 6, 2018 at 3:24 AM
    Bridge4
    Bridge4 [OP] Well-Known Member
    MA
    2003 DCSB Imperial Jade
    I'd love to get rid of my drivers seat for a 4runner adjustable seat. Has anyone tried this or looked into it at all?
    I married my tacoma likes this.
  2. Feb 6, 2018 at 3:52 AM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    Ruggybuggy likes this.
  3. Feb 6, 2018 at 4:06 AM
    Bridge4
    MA
  4. Feb 6, 2018 at 4:36 AM
    Whitetail Assassin
    Tedric
    West Virginia
    No prob. The search thing on here is tricky sometimes but since I knew it was in our forum it was a little easier to find. Best of luck man! Let us know if u do the conversion!
    tonered and Bridge4[OP] like this.
  5. Feb 6, 2018 at 11:31 AM
    Bridge4
    MA
    I was hoping there was a little more information on it, I don't know if I am up to being the experiment lol. I'm bad at wiring so it would have to be pretty close to plug and play for me to feel comfortable with it.
  6. Feb 6, 2018 at 11:33 AM
    Whitetail Assassin
    Tedric
    West Virginia
    Totally understand that. If u don’t end up doing it, I’m sure someone will eventually. I wouldn’t try it, but lots of people r cool with that kind of stuff. Mine is still too new for me to balls up and do something like that!
    Bridge4[QUOTED][OP] likes this.
  7. Feb 6, 2018 at 1:43 PM
    Wedge
    Wedge Well-Known Member
    Yves
    Kebekistan
    17 OR DCSB MGM
    Bestop supertop Bronze Method roost 255/80/17 toyo open country RT Interior LED XenonPro HID low beam
    Best bet would be to find a friend that has a 4runner and try it.
  8. Feb 6, 2018 at 2:07 PM
    Bridge4
    MA
    I happen to own one lol, I guess I should undo the front seat and see. I guess I SHOULD be the experimenter.
    My only thing is, I'm pretty sure I'd have to find wiring for the power seats, which is what I really want out of them. So I'd have to order a harness then find a way to hook it all up.
    Wedge[QUOTED] likes this.
  9. Feb 6, 2018 at 2:20 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    One caution to ask about. You might want to find out if you can remove your seats and reinstall them without getting an airbag light? Our old saab had the seat fixed from a collision. After the harness was disconnected, there was a light on the dash that could only be reset at the dealer.
    Toyotas are probably different, but it might be good to ask before you disconnect them?
  10. Feb 6, 2018 at 2:23 PM
    Bridge4
    MA
    You just unhook the battery for 15 minutes before you disconnect them. I've gutted both the 4runner and taco to soundproof. But thanks for the heads up, it could really mess someone up!
  11. Feb 6, 2018 at 2:23 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Never had this problem on my 2nd gen. And the guys that had their seat foam customized by upholstery shops haven’t but made mention of it. Best bet is simply undo the neg terminal (like should be done with any electrical modification), and then swap the seats if their is concern.
    I’ve put in FRS seats and the airbag light never gave me issues.
  12. Feb 6, 2018 at 2:30 PM
    JdevTac
    Josh
    MD/GA
    2nd gen
    Not sure if the airbag connector for the Tacoma vs 4Runner is the same. I’d imagine it should be but for example my Tacoma connector didn’t match the FRS seats I put in. Was slightly different. So I had to depin them both and swap. Same goes for all the seat buckle setup. Connectors for that may be slightly different and you may end up having to retain a large amount of the Tacoma wiring and transfer it to the 4Runner seat. Hopefully not though.
  13. Feb 6, 2018 at 2:33 PM
    Bridge4
    MA
    I think you are right about the connections being different. I am going to just unhook the front posts and tip the seat back to check it out a little bit closer before I go crazy. I don't want to switch out the wiring etc... I don't trust myself to do it, and don't really want to pay someone either.
  14. Feb 6, 2018 at 2:38 PM
    JdevTac
    Josh
    MD/GA
    2nd gen
    Even if they are different it isn’t too difficult. At least for the 2nd gen, depinning the connector was as simple as removing a retention tab with needle nose pliers and then using a small pin/jewelry screwdriver tip to release the retention clips on each pin. And boom they come right out.
    Rest of all the harness crap was just a matter of unclipping from Tacoma seat and reclining underneath swapped seat/bolting seatbelt receptacle to side of seat.
    The only other part that is annoying is the “Seat position sensor” on the driver seat. I’m imagining this may or may not be a a simple plug n play. Given the 4runner’s May be setup a little different.
  15. Feb 6, 2018 at 2:41 PM
    Bridge4
    MA
    I still need a power seat harness that connects somewhere, I want to be able to move the seat lower than the stock position for a better view, and adjust it a little more than is allowed in the taco.
  16. Feb 6, 2018 at 2:44 PM
    JdevTac
    Josh
    MD/GA
    2nd gen
    Yeah that will be the trickier part. Or getting your hands on a 4Runner wiring diagram to see what’s what.
    That’s why I went with a different seat as the one I put in had manual height adjustment.
  17. Feb 6, 2018 at 2:46 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Excellent.
    Disconnecting the battery is SMRT. :D
    I was just talking about the truck not being happy with the airbag harness being disconnected. It sounds like it is no issue at all. Good stuff.
  18. Feb 6, 2018 at 2:51 PM
    roth_nj
    roth_nj Well-Known Member
    2017 DCLB trd off-road bbp
    I took 4Runner seats and they were a direct bolt up into my 91 Toyota pick up.
    Swapped out the truck bench for a bucket seats. Everything bolted right up....
    So there's that
    Bridge4[OP] likes this.
  19. Feb 6, 2018 at 2:56 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    I looked into it but only because consumer reports mentioned it as a bad thing not to have and all the complaining that is made about it.
    However, in reality, I don't need to adjust my seat up & down all the time, I adjust my seat back or slide back now & then on long trips and that's it.
    But when I did look into it, it meant dealing with air bags that would have to be compatible with the electronics, and electric wiring, fuses and all for what in my case??
    But that's just me, I'm more concerned with the driver's side door handle that they took away and I'd like to get that back :mad:
  20. Feb 7, 2018 at 2:28 AM
    Bridge4
    MA
    Yeah, if I have to change all the electronics out it wouldn't make sense for me I don't think money wise. I'll have to look a little more into it.
