Do 4x4's go bad if they aren't used?
Discussion in 'Technical Chat' started by ShaLor, Mar 21, 2010.
  1. Mar 21, 2010 at 1:31 AM
    ShaLor
    ShaLor [OP] Well-Known Member
    Shane
    Burbank, CA
    07 4x4 Doublecab TRD Off Road
    Custom mud flap removal from rock on trail :), Tailgate Hose Clamp Mod, Cobra 75 wx st CB install, 19 more D-Rings in the bed, Satoshi Grill, Fog Lamp on any time mod. Relentless Fab CB antenna hood mount, LED bed lights, Demello Hybrid Sliders, Undercover Tonneau Cover, Lighted 4x4 switch
    I am looking to buy a 4x4 Double Cab TRD off Road truck.:confused:
    My question is, should I be looking for a truck that has never really been off roading or one that has? One that has done off roading will probably have more wear and tear on it.
    On that "has never been off road" seems to be more appealing because there is likely to be less damage, but if they have never gone off roa:confused:ding they probably never turned the 4x4 on very often (if at all)
    Is this a cause for concern? Does the 4x4 system go bad if it isn't used? ie seals drying up or oil not getting moved around in the front wheels.
    Any advice on this matter would be greatly appreciated.
  2. Mar 21, 2010 at 2:36 AM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    There's no clear and dry answer to your question, a variety of factors come into play, such as how long was the 4x4 not engaged and how often and severe was the 4x4 used.
    It's just like anything mechanical. With time the components will wear out with use as well as without use.
    I really don't think you could go wrong with either, as long as the owners took care of the vehicle.
  3. Mar 21, 2010 at 4:37 AM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    I believe my manual indicates you should operate the truck for 10 miles with the 4X4 engaged at least once a month to keep everything lubed. Try to kick it in for a few straight miles on rainy days when it isn't getting excercised, but that is probably overkill.
    Generally, I would say that the 4WD components will be in as good of shape as the rest of the truck. If the truck looks like it was ridden hard, it probably was.
  4. Mar 24, 2010 at 7:52 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I second what Tillers, and John Taco said.
    When you do find a truck and your testing it out, do engage and disengage the 4x4 actuator a few times to see that everything is in order. Also shift into 4 Low and test that out.
    Do understand that some noise is normal when that happens too. Reading the owners manual should be very helpful as well.
    If I were you and I did make a purchase, I would change the front diff, transfer case and rear diff oil just for peace of mind. It is cheap insurance.
  5. Mar 24, 2010 at 8:07 AM
    pwrstrk02
    pwrstrk02 Well-Known Member
    randy
    kansas city missouri
    2010 4x4,dc,off road, black pearl
    tell me if im wrong, but putting your 4x4 into 4x4 every so often WAS originaly for truck with lock outs. so with the lock outs disingaged, there WASN'T anything "moving" in the front 1/2 of the 4x4 system. so locking in the front end and putting it in 4x4 WAS nessasary to ensure that everything got lubed.
    with newer trucks, lock outs are not options, so everything is always moving, therfore always getting lubed and always wearing (except for the one or two gears that engages the 4x4 in the transfer case).
    so is it actualy nessasary to do it in vehicles without lock outs?
  6. Mar 24, 2010 at 8:16 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    Read the manual.
  7. Mar 24, 2010 at 8:25 AM
    pwrstrk02
    randy
    i did, and i will. but i dont know why you tell me to read the manual, it will tell me nothing about theory or lockouts.
  8. Mar 24, 2010 at 8:30 AM
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    Even if I were not to take my Taco Off Roading Winter in Montana gives me a good 6 months to use the 4 wheel drive.
  9. Mar 24, 2010 at 8:34 AM
    Dilsky
    Dilsky There go my nipples again!
    Shawn
    Edmonton AB
    07 TRD Sport
    2.5" Fox Extendable Coilovers, LR UCAs, Agri-Cover Larado soft top, Pop'n Lock, 48" Hi-Lift Jack, 20" Incubus Offroad rims
    Is it true that if you don't use it, you lose it?
    Is that a serious question?
    No.
    I would say that it wouldn't hurt to engage the 4x4 for a little bit every month. You can't be sure one way or another. Just make sure you are doing it in the appropriate setting and not just anywhere for the sake of doing so (eg pavement is a no-no). Plus every truck deserves a little off road time!
  10. Mar 24, 2010 at 8:34 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I think maybe it is more to keep your actuator functioning. I have noticed that when I use mine a lot I can actually get into 4H while in park. And when I go an extended period without using it I have to roll for it to engage.
    I also believe that jigzor just felt he needed to write something, be it useful or not.
  11. Mar 24, 2010 at 8:54 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  12. Mar 30, 2010 at 8:39 AM
    JML50
    JML50 Well-Known Member
    Like Crom said...make sure you put it in all gears before you buy, but most importantly DRIVE it in all gears. It may go into 4LO or 4Hi and the light come on but you want to make sure it stays in gear and doesn't pop out. I've seen quite a few trucks ridden hard in 4wd and you have to actually hold the stick so it doesn't pop out going over bumps and such. Drive it a mile or so in all gears.
  13. Mar 30, 2010 at 8:49 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The truck (now) has automatic locking hubs... this product has been around since the 60's. Part time 4WDs use hubs to free the front driveline for unnecessary wear... and improved gas mileage. Locking hubs were originally 'added on' to older 4WDs. Newer part time 4WDs like Jeeps and Toyota now have automatic locking hubs that engage when you turn into 4WD from 2WD.
