Do AAL's settle down????
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kuneff, Sep 28, 2010.
  1. Sep 28, 2010 at 5:24 AM
    Kuneff
    Kuneff [OP] Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    I just put Add a Leaf's on my Tacoma last night... My god it rides like a war wagon, not to mention it is sitting a good bit higher than the front now, even with the 5100's all the way up.
    My leaf springs are about 3 weeks old as well.
    Any thoughts???
  2. Sep 28, 2010 at 5:38 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    My new leaf pack settled about a half inch over a month or so, and hasn't settled any more since.
  3. Sep 28, 2010 at 5:40 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    It depends on a lot of things, what kind of shape were the old springs in, if they had been done before they may already have the extra leaf. I have also seen a couple where the overloads were installed upside down, that will certainly stiffen up the ride. I always think that in a truck the back should be a bit higher than the front for hauling, not everyone likes that though. Generally the leafs will ride in after a while but too much leaf spring in the back will certainly make the ride worse although my 98 rides pretty bad now and I still have to redo the leafs but I will have the graphite sliders installed, did it on a couple hotrods and it sure made a difference.
  4. Sep 28, 2010 at 5:47 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    OK, dumb question... Do the over load springs curve upwards or downwards?
  5. Sep 28, 2010 at 6:09 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Last question first: the overloads should curve down, opposite the rest of the pack.
    As for settling, my AAL's maybe settled 1/2 an inch since I installed them, I've had them on for about 4-5 months now so I don't think they'll be changing much any more. Mine actually improved my ride, and no, my leaf springs weren't worn out. I had the frame replacement so my leaf springs are factory new, only about a year old now.
  6. Sep 28, 2010 at 6:30 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    All suspension components will settle.
    Put 200lbs of weight in the bed for a couple weeks and see if that helps settle things down a bit.
  7. Sep 28, 2010 at 11:59 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    Yep... Overload springs are on incorrectly...
  8. Sep 28, 2010 at 12:16 PM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    That's for sure what's making your ride rough. At least you had the balls to admit your mistake.
  9. Sep 28, 2010 at 6:55 PM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    Oh, I will admit I am the first to laugh at my stupidity... But these kinda lessons are the ones I never forget...
    I got the Over Load spring flipped around tonight... My god the truck rides soooo much nicer now...
