Do aftermarket Catalytic converters ever work
Discussion in '2nd Gen. Tacomas (2005-2015)' started by InThePlains, Nov 1, 2022.
  1. Nov 1, 2022 at 5:43 PM
    InThePlains
    InThePlains [OP] Well-Known Member
    My 2008 got hit by the tweakers this afternoon at work. They got away with both cats and the O2 sensor. Drove it to the dealer right before they close, no time for the quote but the foreman said ballpark cost will be $2k , IF they can get the cats.
    My insurance has $500 deductible, but it's a beater 4cyl 5MT with frame damage.
    I'm in a non-SMOG state, no inspections either. I can legally drive with straight pipes. Will the Amazon "direct fit" converters work without throwing codes?
    Here is an example:
    https://www.amazon.com/AutoShack-EMCC64704-Compliant-Catalytic-Replacement/dp/B0916PK3WM/
  2. Nov 1, 2022 at 7:27 PM
    BlueT@com@4×4
    BlueT@com@4×4 Well-Known Member
    2015 TRD PRO Tacoma
    If it said direct fit should be fit plus nothing you worry about inspection.
    friend of mine bought that on Amazon when someone stole his cats and perfectly fit.
  3. Nov 1, 2022 at 7:28 PM
    Bishop84
    Bishop84 Well-Known Member
    Some exhaust shops can weld in a repair with a new cat. Some are better than others but it will get you on your way.
    Toyota cats are wildly backordered right now. I worked on a Tundra today that had a weld in solution to stolen cats, and it seemed to work just fine.
    SR-71A likes this.
  4. Nov 1, 2022 at 7:31 PM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Which janky states don’t care about the environment?
  5. Nov 1, 2022 at 7:34 PM
    InThePlains
    United States
  6. Nov 1, 2022 at 7:36 PM
    InThePlains
    Yeah, that's what the dealer foreman was telling me, too. If, is the key word, they could get the cats.
  7. Nov 1, 2022 at 7:40 PM
    InThePlains
    I need to replace the down stream O2 sensor, I wonder if it's gonna throw a Cat efficiency code with at $100 cat.
    I've only had good luck OEM/Denso sensors before, aftermarket O2 never worked more than couple weeks or months.
  8. Nov 2, 2022 at 4:39 AM
    BlueT@com@4×4
    2015 TRD PRO Tacoma
    Probably what BISHOP84 is better way,
    do you read and ask at Amazon rate for those who's bought it already?
    Looks close to 5 star.
  9. Nov 2, 2022 at 5:06 AM
    lbaldwin22
    lbaldwin22 Active Member
    2006 Silver Access Cab
    I bought one of the cheaper cat pipes from rock auto for around $3-400 if i remember right and have had no issues with it. Been on my 4cyl/5sp for 4-5 years and 50k miles.
    Hardscrabble likes this.
  10. Nov 2, 2022 at 7:36 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Years ago Minnesota had an emission inspection requirement before you could get your plate or tab but they give it up. I guess they figured it was not worth the hassle as most passed and overall few vehicles were taken out of service.
    ryanvar42[QUOTED] likes this.
  11. Nov 2, 2022 at 7:38 AM
    Clearwater Bill
    Billy
    Largo Florida
    Actually I don't think that's accurate, since CATs are a Federal requirement.
    You may get away with it in a non inspection state, assuming they never have roadside random inspections. But getting away with it isn't the same as being legal.
    tinker_troy likes this.
  12. Nov 2, 2022 at 10:17 AM
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    I put aftermarket cats on my car when I slid off the road/a log took out the OEM ones - they were 400$ vs more than the car was worth [say 2K ish]
    It threw a code [CEL light] but I knew it would do this [O2 sensor] and where I live, I could pass inspection with at least 2 codes being thrown so I was done caring about that aspect - I bought my car back from the insurance co. fixed everything and put a new clutch in then drove it for another 100K miles - the CEL light was a minor annoyance at best.
    I did keep a BT dongle in the car to check every now/again and make sure I knew no new codes were being thrown.
    I used to live in FL and they had mandatory emissions inspections at the time - they got rid of this nonsense b/c there was too much shady shit going on with the inspections/repairs/etc - nothing positive came from the inspections [eg removing polluting vehicles] and it just pissed everyone off.
    The county I live in now only mandates a safety inspection - eg do your headlights/brake lights/etc work, if so you are good to go - no OBD stuff
    Torspd and SR-71A like this.
  13. Nov 2, 2022 at 10:32 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    China and India mainly....
    TnShooter and 3pooches like this.
  14. Nov 2, 2022 at 1:54 PM
    Taco'09
    Taco'09 Well-Known Member
    ^^^ This.
  15. Nov 2, 2022 at 3:38 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    It should work. From my experience, aftermarket cats will work, but they just don't last as long as OEM.
    TnShooter likes this.
