Do aftermarket intakes (CAI) make a difference? Yes. Yes, they do.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by canyonchaser, Oct 5, 2020.
  1. Oct 6, 2020 at 12:29 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    cai go woosh make trok go fast
    b_r_o, mojojojo78, theolee and 6 others like this.
  2. Oct 6, 2020 at 12:36 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Anecdotal experience.
    Once upon a time when fuel prices were peaking in 2007, I was driving a 2004 GMC Sierra 2500 HD with the 6L engine and a 4.10 rear end. It did pretty well for fuel efficiency at 17 mpg highway. I was filling 25 gallons every other day. I was looking for an improvement. I was ignorant and drank the kool-aid of a CAI system from K&N hoping for a 2 mpg improvement. Got the system, install was easy, everything was good. I checked my fuel mileage over several tanks.......I was not able to discern any difference, still getting 17 mpg. Any power increase was negligible. Although, the sound was more throaty. After several months.....and more research, I was sorry that I spent the money and time on the CAI system
  3. Oct 6, 2020 at 12:53 PM
    11rex11
    11rex11 Member
    Rex
    Washington
    2015 Tacoma DCSB
    ARB Bumper, 12k Badlands Winch, Offgrid4x4 Dual Batt
    Here's a decently done air filter review with test stands and particulate measurements between popular air filters. The guy does a better job testing than any of us here would do.
  4. Oct 6, 2020 at 1:06 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    An intake by itself will net very minimal gains.
    With a tune, you will see gains. With supporting mods, even more so.
    I have Volant cai with ram air scoop, 3* camshaft gears, 1" IM spacer (not TB spacer), URD spec u headers and URD maf calibrator. Also about 1000lbs of extra gear and armor, I stay even with a stock tacoma from a dig.
    Not sure how much hp I gained but it is much faster than before.
  5. Oct 6, 2020 at 1:08 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    With all due respect without actual data this means absolutely nothing.
    spencermarkd and whatstcp like this.
  6. Oct 6, 2020 at 1:36 PM
    canyonchaser
    canyonchaser [OP] Member Known Well
    Dave
    Utah
    LR TRD PRO MT
    That video really sells the Wix filter, ehy?
  7. Oct 6, 2020 at 1:45 PM
    Knute
    There are other more sophisticated tests performed by certified labs.
    I would consider the results of this testing procedure as directional results.
    The particulate test is a bit off of representing the conditions an air filter is subjected. The static pressure test is also a bit misleading. The pressure should be a differential pressure across the filter.
    Anyhow, consider the results as directional.
    canyonchaser[OP] likes this.
  8. Oct 6, 2020 at 2:32 PM
    coopcooper
    alberta canada
    someone's gonna do that and blow there motor and make a thread about it.
    and im all for it
  9. Oct 6, 2020 at 7:25 PM
    andrew61987
    Another fact people tend to neglect is, if you aren't already maxing out your engine during normal driving, then you aren't going to notice any difference from modest increases in power (if there even is one!) because you aren't using all the power you have to begin with. It's like putting more food on your plate when you already have enough food on there to fill you up. Gains you absolutely nothing. Getting more power when you aren't maxing out your engine is the easiest thing in the world. No mods required, just push the pedal down more.
  10. Oct 6, 2020 at 9:41 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Would the total HP or torque numbers increase? Maybe a little.
    But you would have to chart the HP and TQ numbers along the whole RPM range with the factory system and them with the after market CAI system. You may see increases at certain RPM ranges, which you would feel. But not a peak number increase.
  11. Oct 6, 2020 at 10:02 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    In order to actually feel a difference in performance in a vehicle there has to be a roughly 10% increase in power, does a CAI give your truck 20 more HP? FEEEEEEK NO that said I have seen measured increases with my custom intake piping airflow straightener and FJ cruiser airbox and snorkel with my exhaust, bust even still all together the only actual noticable increase in performance has been MPG.
  12. Oct 6, 2020 at 10:28 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Congratulations, you figured out toyota's secret! They put in a super restrictive air intake so they can upsell you to a Tundra!! Now you're ready to live your life 1/4 mile at a time...
    https://youtu.be/ij57f1pzWjk?t=53
  13. Oct 6, 2020 at 10:32 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    You can also get dry aftermarket filters that will have more airflow than the stock. I swapped mine out for a different one.
  14. Oct 6, 2020 at 10:59 PM
    OldManTacoFeels
    OldManTacoFeels The bells of tacos
    Billy Jr.
    2012 DCLB SR5
    Bilstein 5100s, AFE dry intake, Icon AAL pack, Bed stiffeners, and ideally some UCAs soon
    Same lol I got so excited
  15. Oct 7, 2020 at 4:23 AM
    #35
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    You just compared the Toyota 4.0L to a performance race engine?
    A race engine is pushing the limits and finding the bottleneck and making it bigger, race series rules not withstanding. The intake is far from being a limiting restriction on the 4.0, or almost any other modern EFI engine.
  16. Oct 7, 2020 at 6:33 AM
    #36
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    I know for AFE and K&N you can but I couldn't find any for the trd one. Plus I prefer the regular paper filters because they keep more dirt and dust out. It might kinda defeat the purpose, but I just have it for looks and sound.
  17. Oct 7, 2020 at 6:56 AM
    #37
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    Sound differences aside - I would prefer to get the intake air from a cooler spot. My stock outfit always shows intake air temp 6 - 12 degrees over ambient and in my mind, that ain't cold air. On 100 degree day here in Tucson the inlet air runs 106 on concrete pavement - higher on the blacktop. There could be some better location than the one we have to work with.
  18. Oct 7, 2020 at 7:03 AM
    #38
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Some of the guys on Bobistheoilguy site refer to the best air filter (meaning best filtration) as the best oil filter.
    That won't make sense to some people
    whatstcp likes this.
