Do aftermarket skid plates trap moisture against the frame?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2015WhiteOR, Jun 15, 2019.
  1. Jun 15, 2019 at 1:38 PM
    2015WhiteOR
    2015WhiteOR [OP] Well-Known Member
    Gainesville TX
    I have the stock TRD skid plate up front, but my transmission and cats are protected by this steel plate I bought from a now defunct company. It mounts up flush against the frame in a few places and uses some insertable brackets and hex-head dome machine screws.
    Anyway, should I be concerned that it could be trapping moisture up against the frame? I usually give the frame a wipe down with CorrosionX before I install it, just to provide a clean lubricated surface between the two parts.
  2. Jun 15, 2019 at 1:42 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  3. Jun 15, 2019 at 1:42 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    I have a sos concepts skid trio on mine and have never had to worried about that.
    ovrlndkull likes this.
  4. Jun 15, 2019 at 1:43 PM
    troopah43
    troopah43 Blood Taco
    Ben
    Ashland, OR
    Cheaply Built ‘05 DCSB SR5
    Toytec Boss CMC Chinese Light Bar (front & rear) Stereo Other cheap DIY mods
    I would say no, you do not need to worry about that.
    Dominic4Lo and BillsSR5 like this.
  5. Jun 15, 2019 at 3:06 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    I think there is more moisture in the air than moisture caused by a skid plate
  6. Jun 15, 2019 at 3:13 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I think it would depend on where you live, I live near the coast and everything rust. Heck some of my hand tools rust just sitting in the shed. I also use corrosion x and fluid film on everything. Its a never ending job.
  7. Jun 15, 2019 at 4:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I wouldn’t be too concerned about it.
    There is a lot of other stuff “right against” the frame.
    If it concerns you much, you could squirt a little oil/ rust preventative on it every once in a while.
  8. Jun 15, 2019 at 6:10 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    if you put a light coat of oil or greaae on it before bolting it up like you say I would not worry about it.
  9. Jun 15, 2019 at 6:56 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Just spray a little chain/cable lube in the gaps when you bolt it up. It'll wick in and stay put pretty well.
