do air bags give a rough ride?
Discussion in 'General Automotive' started by soggyBottom, Apr 29, 2024.
  1. Apr 29, 2024 at 12:59 PM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    I have a 3rd gen tacoma with stock suspension and air bags. On the road everything is fine. Off road the rear is SOOOO harsh. It feels like I'm basically riding on bumps. No really but getting close.
    I've tried adjusting the pressure from 5 to 20psi, and there is no difference. My shocks, bushings, etc. all seem fine. Is this expected behavior when using air bags?
  2. May 27, 2024 at 12:12 PM
    Russ68
    Russ68 Member
    Wisconsin
    2021 TRD Off Road
    I had Air Lift bags on my 21 Off-road. Had to take them off because the ride was extremely rough - to the point of pain going over even the smallest bump in the road.
    soggyBottom[OP] likes this.
  3. Jun 17, 2024 at 7:09 AM
    FreeTacos4Everyone
    FreeTacos4Everyone Active Member
    James
    How much did that run you? I'm in the same situation with my 18' Pro.
    I've spent hours trying to sort out the rough ride, if its just a matter of pulling those airbags out I will do so.
  4. Jun 17, 2024 at 7:39 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    I've got the Firestone bags - they work fine. Last two trucks had them as well. The Toyota "quarter ton" springs sucked big time and had no load capacity. Running light with bags - 5 pounds pressure is fine - full of tool box and other equipment, easily adjusted upward. Trucks don't typically ride as fine as passenger cars and to get capacity, tire sizes and pressures are raised accordingly. It sucks to take your truck somewhere to pick up a load - and find you've got the tire pressure down in the "rides nice" zone.
  5. Jun 17, 2024 at 8:09 AM
    Russ68
    Russ68 Member
    Wisconsin
    2021 TRD Off Road
    Didn’t matter how much air I tried (0 psi to max psi), ride was terrible on my truck. Pulled the bags off and threw them in the attic. My back has thanked me ever since. I’ve got a F350 for pulling / hauling (rides way nicer than my Tacoma- both trucks empty). Tacoma is just for fun and (relatively) better MPG for daily commute.
  6. Jun 17, 2024 at 8:22 AM
    545 Well-Known Member
    2015 Access Cab
    Any of you have dayatar cradles?
  7. Jun 17, 2024 at 8:35 AM
    soggyBottom
    I had them. They reduce up travel so much that they are worthless.
