Do all 04 Tacoma 4x4 shafts have u-joints?
Discussion in '1st Gen. Tacomas (1995-2004)' started by nelsondon, Jul 26, 2013.
  1. Jul 26, 2013 at 10:45 AM
    nelsondon
    nelsondon [OP] New Member
    Don
    Jacksonville
    04 Tacoma 4x4 Ext Cab SR5
    I took mine to a Toyota dealer to investigate a clanking noise that I get often when going from Park to Reverse in the mornings. I happen to mention that it was similar to the old U-joint noise I experienced in some of my older cars. His reply was that 2004 4x4's don't have u-joints and I probably need a new drive shaft at about $1800. This from a very large dealership. Thoughts anyone?
  2. Jul 26, 2013 at 10:59 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    Yea, take it to a different dealer.
  3. Jul 26, 2013 at 11:26 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    Almost every car that has to deliver power to the other end of the vehicle uses u joints. Your dealer is a slimy little cretin trying to screw you over.
    I would not recommend any dealer in the world only because they have to answer to higher levels. Local, reputable mechanics are usually their own boss, and look to have happy customers return.
  4. Jul 26, 2013 at 11:27 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Uh never go there again... No u-joints? I bet you talked to a sales guy....
  5. Jul 26, 2013 at 1:08 PM
    nelsondon
    Don
    Jacksonville
    :) So let it be written, so let it be done. I'll find another dealer. Thanks everyone.
  6. Jul 26, 2013 at 6:39 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    And I bet they don't even use Vaseline!
  7. Jul 28, 2013 at 9:11 AM
    ALawrence
    ALawrence Well-Known Member
    Andrew
    Oklahoma City
    03 Tacoma Sr5 Double cab 4x4
    I had the same describe "clanking" tried to change the u joint myself... Long story short took it to a local garage... So what they told me is that tacoma's have an "unserviceable ujoint" that it requires a special press.. So they took it to a drive shaft shop. New ujoints. And what was causing the "clanking" was a spring inside the shaft. It only ran me $200 something. All problems fixed. And they repainted it to :)
  8. Jul 28, 2013 at 9:18 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Unservicable usually means...it's not greasable and doesn't have zerks.
  9. Jul 28, 2013 at 11:06 AM
    QuickSilver
    QuickSilver Member
    North Carolina
    01 Tacoma TRD 4x4 SR5 3.4L Xtra Cab
    Most tacomas have a two piece driveshaft in the rear, these shafts have a u-joint assembly at the joining area. This joint cannot be changed without special tools, most mechanics won't mess with it and replace the entire shaft assembly. That being said, the rest of the driveshaft has standard u-joints that can be changed like any other. Driveshaft shops can replace the assembly for much cheaper than a new shaft.
  10. Jul 28, 2013 at 12:01 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    We have 3 U joints and a Double Cardin Joint.
    however.
    They do say that there is no aftermarket replacement u joint that fits our drive shafts 100% perfect.
    that said..i just went to the parts store and bought one for 30 bucks and swaped it in when mine went bad...not hard to do
