Do All Uni-Ball UCAs squeak?
Discussion in 'Suspension' started by Rooster Feather, May 13, 2013.
  1. May 13, 2013 at 8:44 PM
    Rooster Feather
    Rooster Feather [OP] Member
    Oklahoma
    2007 V6 SR5 4x4
    Really, really want to pull the trigger on a better suspension system. I currently have stock coils up front and an ADL in the rear with 5100s all around. What I didn't know was that the preload on the coil is making for a harse ride. I drive a lot of pasture and wash boarded county roads and my current suspension ain't cuttin' it.
    I've just about decided on the ICONs but am still undecided on the UCAs. From reading, I've found that the Uni-ball design is better as far as travel, bind, and strength. However. The fact that they squeak really makes me question it. Do they all squeak or just certain brands?
    There are so many mods a person can do, but only so much money that I can keep stashed from my wife!!!
    Any and all input would be appreciated!!
    Craig
  2. May 13, 2013 at 8:45 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I've never heard mine squeak
  3. May 13, 2013 at 8:46 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    most do (i think), but there is a brand or 2 that has covers on them so dust doesn't get in there and make them squeak.
  4. May 13, 2013 at 8:50 PM
    Rooster Feather
    Oklahoma
    2007 V6 SR5 4x4
    Nofords08.......funny that you would be the first reply, because during the many hours I've spent reading this forum I've saved about 3 or 4 tacoma build pics that I really like. Ones that are built like the look that I'm going for. Yours is one of them. Very cool!
  5. May 13, 2013 at 8:51 PM
    PLC721
    Patrick
    Chandler, Az
    Thanks man! I make sure to always wash my truck and ill usually spray the uniball off really well, other than that i havent done anything and they make no squeaks.
  6. May 13, 2013 at 8:52 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    just keep them clean and dry, no oil no nothing
    my icon's are squeak free when cclean and dry
  7. May 13, 2013 at 8:53 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The uniball doesn't squeak, but the urethane bushings do unless you thoroughly and frequently grease them.
    The uniball is stainless, but the misalignment spacers All-Pro uses are bare 4130 chromoly, so they'll rust if your area sees road salt in the winter. Icon tubular UCAs and Total Chaos UCAs use stainless spacers.
  8. May 13, 2013 at 8:53 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    also was going to point out grease the bushings on a weekly basis
  9. May 14, 2013 at 5:47 AM
    Rooster Feather
    Oklahoma
    2007 V6 SR5 4x4
    Do the control arms have grease zerks to allow easy greasing?
  10. May 14, 2013 at 8:24 AM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    Yup very easy
  11. May 14, 2013 at 9:24 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    I have had Camburg and TC's in which both were noisy as hell, my Built Rights have never made any noise.
  12. May 14, 2013 at 9:29 AM
    Large
    Large Red
    If the uniball starts to pit it makes some wrenching noises, hit it with a shot of triflow teflon lube and it shuts it up for 5k miles or so.
  13. May 14, 2013 at 9:31 AM
    SoCaltaco65
    better option, plus it drys
  14. May 14, 2013 at 9:34 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Gotta keep your balls greased. :cool:
  15. May 14, 2013 at 9:47 AM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    Use the same on mine :thumbsup:
  16. May 14, 2013 at 10:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Never had mine squeak
  17. May 14, 2013 at 10:42 AM
    DevL
    DevL Well-Known Member
    Mine dont squeek. They are Desert Products with stainless uniballs. Stainless is optional for Total Chaos which is why you get reports of squeek and no squeek. Get all stainless and grease the bushings every oil change.
  18. May 14, 2013 at 2:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It doesn't matter if they are chrome, or stainless. What makes them squeak is the steel they are made of. A softer steel is less likely to squeak. Some company's have used a harder steel, thus had squeaks.
  19. May 14, 2013 at 2:56 PM
    SoCaltaco65
    Not all UCA squeek at the uni-ball, in my Camburg case the machined cup was a tad too big and the uni-ball was moving around.
  20. May 14, 2013 at 4:23 PM
    KenLyns
    Belly of the Beast
    ^If the cup is slightly oversize, you can use Loctite retaining compound. If the clearances are too large, you can fold up the thin leaves of a feeler gauge as shim stock.
    The stainless uniball is still good as new on mine. But the misalignment spacer is rusting. Since the spacer forms part of the ball surface at larger articulation angles, mine makes noise when the suspension moves a lot. Small pavement cracks, expansion joints, etc. don't cause squeaking in the uniball.
    In hindsight I would've been better off with Icon UCAs with stainless spacers, but they weren't available at the time.
