Do bed stiffeners just transfer stress somewhere else?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by photodoc, Apr 17, 2025.
  1. Apr 18, 2025 at 10:47 PM
    #41
    Kwikvette
    Fresno County
    4 run, 2 don't
    Not often do I find myself in the presence of another intellectual such as yourself :hattip:
  2. Apr 18, 2025 at 11:00 PM
    #42
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    soundman98 and Kwikvette[QUOTED] like this.
  3. Apr 19, 2025 at 9:41 AM
    #43
    PoorWhiteBoi
    PoorWhiteBoi Active Member
    2022 SR5
    I've had a camper top on my truck for a year and half and now thinking about adding some stiffeners. I can just install the stiffeners now right? Or do I need to remove the cap from the bed for a better install?
  4. Apr 19, 2025 at 2:18 PM
    #44
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    yes, you can just install them now. there really shouldn't be anything about the topper that should stand in the way of the stiffener install.
  5. Apr 19, 2025 at 4:57 PM
    #45
    photodoc
    photodoc [OP] Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    While we are talking about it...with the Cali Raised bed stiffeners or really with any of them do they interfere with carrying 4x8 sheets of wood etc?
  6. Apr 19, 2025 at 5:37 PM
    #46
    545
    545 Well-Known Member
    2015 Access Cab
    Shouldn’t be an issue as you can’t lay a sheet flat on the bottom of the bed, and at wheel well height it’s way more than 4’ clearance
    photodoc[QUOTED][OP] likes this.
  7. Apr 19, 2025 at 6:15 PM
    #47
    photodoc
    Northern Kentucky
    '23 TRD PRO 6MT
    Yeah I was just making sure at wheel well height it would still be clear, renovating my house and need to be able to get sheets of plywood and drywall in there. TY
  8. Apr 19, 2025 at 6:39 PM
    #48
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    The original question is an interesting one. If you jack one wheel up until the other lifts off the ground you will see a severe misalignment on the tailgate. So when you stiffen the bed those bed stiffeners and surrounding structure will be taking a significant load in such a situation. It may actually decrease your flex a tiny bit but it will also help stiffen things in a way that will improve ride quality.
    photodoc[OP] likes this.
  9. Apr 19, 2025 at 8:18 PM
    #49
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    MGMDesertTaco[QUOTED] likes this.
  10. Apr 19, 2025 at 8:30 PM
    #50
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    What a PHD treatise to evaluate "Pickup bed Stress due to bed loading and ladder frame flexing from roadway irregularities".
    It really is a two way street. A rigid bed box could amplify stresses elsewhere due to frame flex.
    What has a front...has a back!
  11. Apr 19, 2025 at 8:33 PM
    #51
    Mach
    My general philosophy is to keep fixing and improving the things that break until they stop breaking. When you run out of things to fix you obviously need to push things harder :)
  12. Apr 19, 2025 at 8:36 PM
    #52
    Mach
    On a more serious note in this case you are really just transfering the load to the bed stiffeners and their attachment points instead of the places we already know flex and break. Havn't heard of any beds or surrounding structures breaking from using them and I dont see any negatives outside of those areas.
    photodoc[OP] and TacoTime55 like this.
  13. Apr 20, 2025 at 7:37 AM
    #53
    photodoc
    Northern Kentucky
    '23 TRD PRO 6MT
    Thats exactly where my head was at.
  14. Apr 20, 2025 at 8:23 AM
    #54
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It's the sides of the bed flexing outward that causes the cracking below the taillights. Stiffening up the sides in relation to the bed floor isn't going to damage anything else.
  15. Apr 20, 2025 at 11:27 AM
    #55
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    That’s my thought.
    I’ve even read in other Bed Stiffener threads (can’t remember how long ago) about the difference in stability (strength wise) after install.
    Now, I’m glancing at the back end of my bed through the side mirror…checking flex. lol
    I’m happy with my install. I know when I get my DB Tonneau cover, my bed will be ready for install.
  16. Apr 20, 2025 at 5:51 PM
    #56
    VTCAL
    2021 Sport
    Bed mountings would come to mind as possible "stress amplification" points.
    Wi;; that require a double blind evaluation? '[)
  17. Apr 21, 2025 at 3:23 AM
    #57
    photodoc
    Northern Kentucky
    '23 TRD PRO 6MT
    Triple blind
  18. Apr 21, 2025 at 9:47 AM
    #58
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Blind drunk?
  19. Apr 21, 2025 at 10:01 AM
    #59
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Speaking in terms of force, if you assume a load which would pull/push the bed sides apart, by adding an L-shaped stiffener you are introducing a moment in the corner and that force is transferred as upward force on the bed of the truck, with the most pull-out torque seen at the bolt closest to the center (assuming no stiffener deflection). Note this is more applicable to a dynamic frame of reference than a static one.
  20. Apr 21, 2025 at 9:18 PM
    #60
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    Stress is force per area. Think pressure - PSI.
    Toyota, for some unknown reason, put a notch on the inside corner of the bed frame. (Circled areas below.) All the bending force has to go through that thin sheet metal in the notch, resulting in extremely high ‘stress’, and a very predictable failure point.
    Most bed stiffeners don’t “just transfer stress somewhere else”, per se. They transfer or re-distribute the forces over a larger area, or different path, resulting in lower stress levels. (Provided the designer knows what they’re doing.)
