Do body lifts affect towing ratio's?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cpd149, Mar 12, 2013.
  1. Mar 12, 2013 at 6:08 PM
    cpd149
    cpd149 [OP] New Member
    Virginia
    '08 taco rugged trail
    I am having a 2.5 daystar body lift installed on my 08' Taco. Will this affect my towing ratio? I am purchasing a camper that weighs 3093 lbs. empty. Will the added weight along with the body lift harm or decrease my tow ratio?
  2. Mar 12, 2013 at 8:11 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    What do you mean by tow ratio? Do you mean toe rating? A body lift won't affect how much you can tow.
  3. Mar 12, 2013 at 8:18 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Your tow hitch is attached to the frame...crawl under your truck once in a while :)
  4. Mar 12, 2013 at 8:19 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    You will obviously need to use the frame mounted hitch, that will be completely unaffected by the lift. I wouldn't have put on a body lift but then again its not my truck.
  5. Mar 13, 2013 at 1:35 AM
    03f5sp
    Bill
    Wisconsin
    ^^This
    If I had a body lift and a bumper hitch I would be afraid to tow anything.
  6. Mar 13, 2013 at 4:47 AM
    cpd149
    Virginia
    Sorry for the confusion, let me clarify. Will the body lift change my towing rating/capacity? Also will having the body lift and towing items over 3000 lbs. damage my diff. or drive shaft? The reason i ask is I have heard it might over time.
  7. Mar 13, 2013 at 5:12 AM
    Large
    Large Red
    No, unless you have the receiver on your bumper (and your bumper isn't connected to the frame). I'm not sure about weight in the bed and a BL though.
  8. Mar 13, 2013 at 8:10 AM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Best question here is why are you doing a body lift vs a suspension lift.
    Body lifts are crap
  9. Mar 13, 2013 at 8:24 AM
    Bubbabooie
    Bubbabooie Member
    Hunter
    Chesapeake, VA
    12 Tacoma
    4-5" RCD LIFT KIT 35x11.50 Nitto Terria Tires
    I have a 3" body lift and 3" suspension on my truck and tow things and pull people out. I haven't had any problems with it. As long as your hitch is bolted to the frame (if its the factory then it is), then your safe.
  10. Mar 13, 2013 at 8:44 PM
    cpd149
    Virginia
    My truck has the towing package, its a class IV hitch. The reason for the body lift is a freind has one, I liked so I went with it.
  11. Mar 13, 2013 at 8:47 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    if it isnt installed already...please get something else...even a coil spacer and blocks are better
  12. Mar 13, 2013 at 8:50 PM
    VolcomTacoma
    Jeff
    NorCal
    Seriously. If you take your truck offroad ever, I mean, accidentally drive on your front lawn occasionally, DO NOT GET A BODY LIFT.
    Do some research in here for like an hour...tops.
    You will run screaming from a body lift so fast your tow hitch will fly off
  13. Mar 13, 2013 at 8:56 PM
    BradyT88
    BradyT88 Well-Known Member
    The rear bumper is also attached to the frame and unaffected by a body lift. Just FYI.
  14. Mar 13, 2013 at 9:30 PM
    BradyT88
    Yours is only a 1" though isn't it? Mine is a 1" and they are much more reasonable. I find most bodylift pieces for 2+" lifts are sketchy looking... I'd be worried about them bending or breaking under hard stress.
  15. Mar 14, 2013 at 7:45 AM
    cpd149
    Virginia
    I'm actually having spacers and blocks installed as opposed to an actual body lift, "body lift" was just the terminalogy that the installer used.
  16. Mar 14, 2013 at 7:57 AM
    BradyT88
    Yeah I upraded my cab bolts to grade 8 as well:D Mine survived but I haven't actually checked every little puck for damage though. haha
  17. Mar 14, 2013 at 8:36 AM
    nathan3306
    nathan3306 Well-Known Member
    Nathan
    Charleston AFB, SC
    2012 SR5 DC 4X4
    Op the answer is no.. when you put larger tires on then your answer will be yes. I wouldn't know where to begin on the math but with a larger tire it will decrease your towing ratings. It will be harder for you truck to turn larger tires and pull 3K pounds rather than stock.
    I've seen numerous body lifts and have yet to see a total problem with them. I wouldn't have it on my truck but thats just me. Blocks and spacer will be fine for just about anyone. Don't get the spacer over the top of coil... bad luck with those on my 150. No real problems but you can tell its beating the shit outta all my components.
    hope this helps some,
    Nate
  18. Aug 12, 2014 at 12:56 PM
    specialized7
    specialized7 Well-Known Member
    ,Saskatoon, Canada
    05 v6 4x4
    I have had a body lift on my truck for 200 000 kms and i have also had a truck camper in the back aswell. I tow a 4500 pound eavestrough trailer 80% of the time. i have had zero issues. I havent done much research.. because i havent had to.. maybe someone can post a link to someone having problems with a body lift?
  19. Aug 12, 2014 at 1:10 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    http://www.tacomaworld.com/forum/1s...stock-gen-1-clear-35-12-5s-3.html#post5272603
    Post #48
    Also here is another failure:
    http://www.yotatech.com/f116/body-lift-broken-mounts-82172/
