Do Chaos UCA need oil?
Discussion in 'Suspension' started by rzimm001, Sep 17, 2009.
  1. Sep 17, 2009 at 4:19 PM
    rzimm001
    rzimm001 [OP] Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Just installed my UCA's and am loving them. I was just wondering if the uniball could stand to be sprayed with any kind of lubricant. I already greased the red bushings. Now I'm just wondering about the ball. Any ideas? Thanks
    Bobby
  2. Sep 17, 2009 at 4:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    NO OIL. Use a dry teflon lube.
  3. Sep 17, 2009 at 4:25 PM
    rzimm001
    Bobby
    Wildomar
    Hmm... Teflon. Is that easily acquired at my local hardware store? Is it like a powder or what?
    Bobby
  4. Sep 17, 2009 at 4:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Try and find a Spray Teflon lube. Local Hardware store should carry it. You should only have to apray them once a year or so.
  5. Sep 17, 2009 at 4:31 PM
    rzimm001
    Bobby
    Wildomar
    Thanks Chris, sounds good. One more question since your online. I noticed when I do my serious offroading, occasionally it results in the entire steering wheel being off center (Turned about 10% to either the right or left) although the handling feels solid. The alignment shop always get it back to being perfect again but the guy said tacomas have a weak bushing in the rack and pinion that can move right or left somewhat. Is there any practical upgrade for this problem or am I just asking too much of the taco?
    Thank you
  6. Sep 17, 2009 at 5:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Energy suspension has some Poly bushings, but Im not sure if they are out for the sencond gens yet. I dont know why your alignment has been knocked off center. I have beaten on mine pretty good, and its still straight. Im wondering if the alignment shop isnt setting the cam adjusters tight enough.
  7. Sep 17, 2009 at 7:20 PM
    rzimm001
    Bobby
    Wildomar
    What should I torque them to? I'd be curious if the aren't torqued down tight enough. Anything else I can tighten down?
  8. Sep 17, 2009 at 7:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The Uniball gets torqued to 95# or so. Not to exceed 100#. UCA bolt is 83# IIRC.
  9. Sep 17, 2009 at 8:18 PM
    rzimm001
    Bobby
    Wildomar
    What about the camber adjusters you were talking about. How tight should those be?
  10. Sep 17, 2009 at 8:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not sure. I think about 80 to 100#...The alignment shop shoud torque those though.
