Do coils go bad?
Discussion in 'Suspension' started by inwood customs, May 16, 2024.
  1. May 16, 2024 at 9:38 AM
    inwood customs
    inwood customs [OP] Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Hey all, I've had Billie 5100s on all 4 corners for about 100k and eibach 620 coils. The shocks are def being replaced. I did the rears, how hard are the fronts?
    Also do coils get worn out? If so what are the clues?
    I have a avid off-road light bar, blower, and sliders
    Tia
  2. May 16, 2024 at 9:56 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Springs can wear out, but generally if they're not rusted and were specced properly for the weight rating of the vehicle you'll be fine to reuse, especially if they only have 100k on them. You're likely feeling the effects of improper damping with the shocks blown out.
    To replace the fronts, you'll need to remove the coilover from the truck and use spring compressors to safely remove the shock from the coilover assembly.
  3. May 16, 2024 at 10:42 AM
    inwood customs
    Dave
    Thank you
    drizzoh[QUOTED] likes this.
  4. May 20, 2024 at 12:19 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Seconded
