Do ditch lights lower MPGs?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eurowner, Apr 14, 2023.
  1. Apr 14, 2023 at 4:59 PM
    #141
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Seems everyone in TW is ... ummm ... "unique".
    TXpro4X4 likes this.
  2. Apr 14, 2023 at 5:18 PM
    #142
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    I'd say so
    :cheers:
    eurowner[OP] likes this.
  3. Apr 14, 2023 at 5:33 PM
    #143
    eurowner
    eurowner [OP] Duke Sky
    Scoty
    I didn't say I was unique.
  4. Apr 14, 2023 at 6:47 PM
    #144
    Tiny's Taco
    Tiny's Taco The Wanderer
    Shenandoah Valley
    2018 Inferno TRD Sport
    That's a horrible idea. What time?
    Yes, you should.
  5. Apr 14, 2023 at 7:09 PM
    #145
    spamy
    spamy Truck guy
    NorCal
    2017 Tacoma Sport 4x4
    You have to shine the lights towards the rear to achieve light speed.
    EL Taco Verde likes this.
  6. Apr 14, 2023 at 7:22 PM
    #146
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    My Tacoma headlights are definitely measured in candlepower. Like 2 candles or maybe 3 candles at most.
  7. Apr 14, 2023 at 7:47 PM
    #147
    OrangeCrash
    OrangeCrash Well-Known Member
    Kingman, Az
    Only if you drive with them on during the daytime
  8. Apr 14, 2023 at 7:47 PM
    #148
    eurowner
    Scoty
    Brighter forward facing lights make the air molecules hotter so the air is less dense, so you go faster which reduces mpgs.
  9. Apr 14, 2023 at 7:48 PM
    #149
    eurowner
    Scoty
    If you have two headlights, how do you have the candlepower?
  10. Apr 14, 2023 at 7:48 PM
    #150
    eurowner
    Scoty
    See post #148
  11. Apr 14, 2023 at 8:01 PM
    #151
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    do you even upshift bro?
  12. Apr 14, 2023 at 8:04 PM
    #152
    RichochetRabbit
    So LEDS being cooler than halogens do not have the effect of speeding up the vehicle? Or do LEDs just shift the vehicle past "warp" into "trans-warp"?
  13. Apr 15, 2023 at 4:30 AM
    #153
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    If you want better mpg's then all you have to do is drive South all the time because you're going down hill.
    :nuclear:
  14. Apr 15, 2023 at 8:40 AM
    #154
    RichochetRabbit
    This thread is going downhill fast.
    Tiedie[QUOTED] likes this.
  15. Apr 15, 2023 at 9:20 AM
    #155
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    OR......put your truck in neutral facing West, and let the Earth rotation move under your truck.......
  16. Apr 15, 2023 at 9:22 AM
    #156
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Can confirm, lost 4 mpg from my ditch lights. I also started driving 100 mph vs 80 mph since I can see so much better with them on the highway.
  17. Apr 15, 2023 at 12:16 PM
    #157
    eurowner
    Scoty
    LEDs are slower since the diode doesn't transmit heat. They are faster when going backward.
  18. Apr 15, 2023 at 12:20 PM
    #158
    RichochetRabbit
    What about adding resistors to the power cable generating a focus heat beam like phasers in front of the default emitters?
  19. Apr 15, 2023 at 12:23 PM
    #159
    eurowner
    Scoty
    D means to drive without focusing on what ratio I am in. If I wanna boy-racer, I'll tip into the S gate.
  20. Apr 15, 2023 at 12:24 PM
    #160
    eurowner
    Scoty
    I live at the southern bottom of a mountainous valley and everywhere ascends.
