Do ditch lights lower MPGs?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eurowner, Apr 14, 2023.
  1. Apr 15, 2023 at 12:25 PM
    #161
    eurowner
    eurowner [OP] Duke Sky
    Scoty
    If you installed brighter ditch lights, you should be able to go back to driving 100mph again!
  2. Apr 15, 2023 at 12:26 PM
    #162
    eurowner
    Scoty
    I want the power to go both ways so I front and rear heat beams. I don't want resistors on my power cables.
  3. Apr 15, 2023 at 12:28 PM
    #163
    eurowner
    Scoty
    How will I stop the Earth?
    chris4x4[QUOTED] and Tiedie like this.
  4. Apr 15, 2023 at 12:30 PM
    #164
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Sorry ... stupid idea. I guess all of the images of ripped out dashes and custom fuse panels in the engine bay just started me thinking ...
  5. Apr 15, 2023 at 12:34 PM
    #165
    eurowner
    Scoty
    Move all the stuff from the dash and out it under the engine bay; lower COG and more intertior room!
  6. Apr 15, 2023 at 12:36 PM
    #166
    RichochetRabbit
    Adjust the power seats to fully recline flat and you can take a nap on long journeys.
  7. Apr 15, 2023 at 12:42 PM
    #167
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    No that’s what I said, I can go 100mph now because of the lights :cool:
  8. Apr 15, 2023 at 12:45 PM
    #168
    eurowner
    Scoty
    :facepalm::lalala:
  9. Apr 15, 2023 at 12:45 PM
    #169
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Put down on ground like Flintstones:rockband:
  10. Apr 15, 2023 at 12:49 PM
    #170
    eurowner
    Scoty
    If I could. I have an RC 6" lift where I had to cut out all the cross frame-members, installed front and rear Seat Jackers, and have the power seat at the highest setting.
    Tiedie[QUOTED] likes this.
  11. Apr 15, 2023 at 12:51 PM
    #171
    RichochetRabbit
    Who wants to stop it? I say speed it up 4x-5x and make it an amusement ride.
    Tiedie likes this.
  12. Apr 15, 2023 at 1:02 PM
    #172
    Tiedie
    David
    WFOY
    Slam on brakes on ice
  13. Apr 15, 2023 at 1:08 PM
    #173
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You cant. Thats why you have to put the vehicle in Park, or put the brakes on.
  14. Apr 15, 2023 at 1:18 PM
    #174
    eurowner
    Scoty
    Damn, 460 meters per second already and you wanna go faster?! I may need to engage crawl control STAT!
  15. Apr 15, 2023 at 1:20 PM
    #175
    eurowner
    Scoty
    Why can't I do both? What if I use Park, brakes on, and parking brake lever up?!
    chris4x4[QUOTED] likes this.
  16. Apr 15, 2023 at 1:22 PM
    #176
    eurowner
    Scoty
    On ice, I always use four chains.
  17. Apr 15, 2023 at 1:33 PM
    #177
    RichochetRabbit
    I'll stop the world and melt with you ...
    eurowner[QUOTED][OP] likes this.
  18. Apr 15, 2023 at 1:48 PM
    #178
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    Modern english, please. Some of us don't speak in riddles.
    eurowner[OP] likes this.
  19. Apr 15, 2023 at 2:02 PM
    #179
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    It's clown threads like this that make me want to flee this place, never to return. But it's also threads like this that keep me coming back. Very Zen, I think?
    Cushmaat and eurowner[OP] like this.
  20. Apr 15, 2023 at 5:16 PM
    #180
    eurowner
    Scoty
    :argue::duel::drunk::cheers::yes:
