Do front coils settle over time?
Discussion in 'Suspension' started by xfactor, Mar 10, 2010.
  1. Mar 10, 2010 at 8:00 AM
    xfactor
    xfactor [OP] Well-Known Member
    Ray
    Texas
    2010 BSP PreRunner Sport
    Just installed Toyotec/Eibach Lift Coils and 5100's (set at 0). Got a little more lift than Toyotec specs:
    892-620 Replaced by 112-620; same spring except now has Toytec's name on it.
    Eibach front coil spring kit (set of 2) for:
    95-04 Tacoma = 3" lift
    96-02 4Runner 3" lift
    05-10 Tacoma 03-10 4Runner and FJ 1.6" lift
    I got about 2" front left and 2 1/2" front right. Truck sits level on the drivers side, has a slight
    rake (front up) on passenger side.
    Will these settle or relax any over time?
    p.s. The ride is great, a little bumpity on small road cracks but overall great feel and recovery.
    I did a test drive and launched over a few road humps, front did good, rear bottomed out though.
  2. Mar 10, 2010 at 8:01 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Gravity will make it settle. Just wait.
  3. Mar 10, 2010 at 8:05 AM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    Give it a few weeks. It will settle.
  4. Mar 10, 2010 at 8:49 AM
    xfactor
    Ray
    Texas
    Thanks for the input, I knew rear springs settled, wasn't so sure about fronts.
    Ray
  5. Mar 10, 2010 at 8:58 AM
    Devildoc
    Devildoc Well-Known Member
    Lincoln, California
    Speedway Blue off road
    Running board, K&N air filter, Nitto Terra Grapplers G2 on ProComp 7089(285/70/17), 3" front lift and 1.5" AAl rear, all with bilstein 5100's with Eibach spring, 1/2 spacer in driver side and 1/4 spacer on the passenger, Wicked Flow exhaust, Debadge, satoshi raptor grille (HomerTaco)
    Just installed mine 2 weeks ago with the same setting and is not settling down much. I got about 1 5/8 inch from both side from the stock measurements. Left side is about less than 1/4 inch lower than the right side because I have a 1/4" spacer installed. I have a 4x4 and double cab so, this maybe why I only gain about 1 1/2 inch.
