Do front tires of tacomas or rear tires wear faster?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sh56, Feb 21, 2024.
  1. Feb 21, 2024 at 8:43 PM
    Sh56
    Sh56 [OP] Well-Known Member
    Shara
    2022 Lunar Rock Tacoma TRD off road
    Do tacomas front tires or rear tires wear faster?
  2. Feb 21, 2024 at 8:49 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Usually rears wear faster unless your alignment is borked.
    Berchico and ScrippsRanch67 like this.
  3. Feb 21, 2024 at 8:50 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  4. Feb 21, 2024 at 9:33 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Depends on where you drive and what else is in/on the truck.
  5. Feb 21, 2024 at 9:40 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Not with regular rotation at 5,000 miles
  6. Feb 21, 2024 at 9:46 PM
    TacoTuesday1
    FL
    Rear. It is rear wheel drive. That is where the force goes accelerating.
    RWD vehicles wear the rear first.
    Cars that wear front tires have engine weight forward and are front-biased drivetrain cornered harder.
    if you are not sure
    Take a $3 gauge. Measure your tires.
  7. Feb 21, 2024 at 9:53 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Front, if you turn a lot. Rear if you burnout a lot. Just rotate now & then.
  8. Feb 21, 2024 at 9:56 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    b_r_o likes this.
  9. Feb 21, 2024 at 10:00 PM
    Robnik
    Rob
    Greenacres, Florida
  10. Feb 21, 2024 at 10:01 PM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Depends on how you drive really.
    Like a grandpa - Bout even.
    Lots of loads the rear.
    Smokey burn outs - rear.
    Harsh cornering at speed - front.
    Failure to negotiate a corner at speed - wear shifts to the roof.
  11. Feb 21, 2024 at 10:07 PM
    Robnik
    Rob
    Greenacres, Florida
    Thank you, Greg (from Grandpa) :thumbsup:
    GTGallop[QUOTED] likes this.
  12. Feb 21, 2024 at 11:51 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    1 vote for the front
    barch88 and na8rboy like this.
  13. Feb 22, 2024 at 6:17 AM
    GTGallop
    Greg
    Anthem, Arizona
    Dash Cams and Hams!
    That's how I drive too.
  14. Feb 22, 2024 at 6:20 AM
    toyotahenry
    toyotahenry N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    i can’t understand how OP couldn’t answer the question themselves lmao
  15. Feb 22, 2024 at 8:16 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Rotation evert 5-6k and they will wear evenly. Proper inflation and alignment.
    gudujarlson likes this.
  16. Feb 22, 2024 at 8:34 AM
    MGMDesertTaco
    Fronts always wear faster from turning. Drivers front a little more than passenger front as the drivers side has more weight on it. Rear tires will wear excessively fast if you're constantly towing or breaking the tires loose. I rotate every 5k. There's a few pattern options for rotating depending upon vehicle driveline type. For the tacoma I do front to back, back to front.
  17. Feb 22, 2024 at 9:06 PM
    barch88
    barch88 Well-Known Member
    Michigan, USA
    2022 Tacoma SR utility package
    Front wear faster. Yes it's a RWD truck but steering and front end weight play a much bigger role.
  18. Feb 22, 2024 at 9:18 PM
    TA2016
    Oregon
    Thank you for this thread. Reminded me to rotate my tires today. My Michelin LTX Defenders are wearing nicely and forgiving since I am over 5K since rotating.
  19. Feb 22, 2024 at 9:20 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    My new Toyos are definitely wearing in the rear much quicker than the front. No burnouts, though some hard acceleration. I have done a lot of intentional very hard braking and cornering and it took forever and lots of that to get the little spikes to start to go away up front. Meanwhile they were gone in the rear after not much time at all.
    I’d say RWD wears the rear out more quickly, at least in my experience.
    Superdave1.0 likes this.
  20. Feb 22, 2024 at 9:56 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    As a wild guess I'd say rear will wear faster on a Tacoma. With that said I've owned many Front wheel drive cars and those definitely wear the fronts faster. Much faster.
    Gritto likes this.
