Do I have a 1GR-FE engine?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, Dec 13, 2013.
  1. Dec 13, 2013 at 7:21 AM
    TOYOTA 09
    TOYOTA 09 [OP] Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    My manual says to replace the plugs on my Tacoma at 30K ONLY if. It's a 1GR-FE engine...my window sticker says 236HP 4.0 V6 DOHC 24V engine w/VVT-i
    2009 SR5 MT access cab....
    Had the dealer do the 30k service and my service receipt says nothing about changing the plugs....do I have the 1GR-FE engine? Should the dealer have changed my plugs anyways? Thoughts?
  2. Dec 13, 2013 at 7:45 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
  3. Dec 13, 2013 at 7:48 AM
    Joe D
    Joe D .
    I'm Joe D and I approve of the quoted answer. :D
  4. Dec 14, 2013 at 2:41 AM
    TOYOTA 09
    Maine
    Where would it say this...my manual?
  5. Dec 14, 2013 at 3:12 AM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    4.0 v6 = 1GR
  6. Dec 14, 2013 at 3:35 AM
    zacksblacktaco
    zacksblacktaco Well-Known Member
    west virginia
    06 trd sport access
    AEM CAI Throttle body spacer Borla cat back exhaust Doug Thorley long tubes RCD 4.5 anzo halo projectors with 4300k hids 12000k hid fogs T-rex stainless mesh mesh grille kit in pro car wear LED taillights & 3rd brake LED reverse lights LED license plate lights LED dome & map lights all Kicker speakers with 15 inch L7 subwoofer Jensen 7inch flipout headunit Trd sport seatcovers Re-badged red Tacoma
    there is a sticker under the hood on the passenger side that should state 1gr-fe
    also should be on the fan shroud in the engine bay
  7. Dec 14, 2013 at 9:55 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Thing is, if you call them on it they'll say they did it but forgot to note it on the receipt. But who knows for sure without actually pulling a plug to verify.
    This is why I do my own work. Changing plugs is easy and I know for a fact it's done as well as possible and nothing else is screwed up.
    Truth be told, these plugs can go 60k no problem. Maybe you should bargain with these guys for some sort of freebee to compensate.
  8. Feb 18, 2015 at 2:29 PM
    baxter
    baxter Member
    Baxter
    Round O, SC
    2005 Tacoma Quadcab 4x4
    Stock
    Did my first set at 177k. Looked good.
  9. Feb 18, 2015 at 4:12 PM
    cotaco05
    cotaco05 Well-Known Member
    Jeff
    CO
    2023 Tacoma
    I just changed mine at 143xxx. They appeared original (I bought the truck at 132xxx, so unsure), gap was quite a bit wider but the truck still ran well. Now I get an extra 1 mpg and smoother idle. So it would appear they'll last well over the 30k.
