Do I have a bad alternator???
Discussion in 'Technical Chat' started by MadeInMaine, Nov 26, 2010.
  1. Nov 26, 2010 at 9:44 PM
    MadeInMaine
    MadeInMaine [OP] MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Hey Fellas,
    Is there a way to test and see if my alternator is crapping out on me?
    Cheers
  2. Nov 26, 2010 at 9:46 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    yes, most auto stores can test it...
    what are the symtoms you are facing? easiest way i found to test the alternator is to start the car and see what the voltage across the battery is. should be 13-14VDC
  3. Nov 27, 2010 at 7:06 AM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Symptoms are my clock is resetting to 1:00 every time I turn the truck on.
    My ultragauge says Im rolling at 13.4, so that isn't the problem. I am really trying to figure out why the clock is resetting all the time, and once yesterday, the clock didn't even turn on. Sounds like a fuse or connection, but basically the clock is thinking that the battery is disconnected every time...
  4. Nov 27, 2010 at 7:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Your voltage seems kinda low. You should be closer to 14 volts. Check the battery terminals.
  5. Nov 27, 2010 at 7:10 AM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Grassy Ass Chris
  6. Nov 27, 2010 at 7:53 AM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Make sure the battery terminals are clean and tight. Poor, bad connections can be a cause of a lot of grief. Really it's Direct Current it really does not work well on poor connections. Even after you fix it, it might take time to go away if the battery was not charging properly. It's not only the connections on the posts of the battery where problems could be, the wires could be connected poorly to the terminals themselves.
    I give a lady a boost the other day and her battery terminals where like just sitting on the battery and the wires where all goofed to hell too so it was not even charging up. Really poor shape. No wonder she was having problems.
