Do I have a bad alternator?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Plasmech, Oct 19, 2023.
  1. Oct 19, 2023 at 10:41 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Turn a bunch of electrical stuff on like high beams and fan blower and check again running
    And unplug that field connector like mentioned above, see if the noise goes away
    TnShooter, HondaGM and SR-71A like this.
  2. Oct 19, 2023 at 11:27 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    That what I went with when I had to replace the one on my mothers Honda Pilot.
    Reman Denso. So far, so good. :fingerscrossed:
    Scotfree likes this.
  3. Oct 19, 2023 at 11:35 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Got right around 100k on my original alternator,
    Currently at 45k on the reman denso zero issues.
    Edit - I attribute the failure of the first one from lots of back to back WOT high rpm pulls during the hayday of HPTuners and figuring out tunes and gathering logs. The alternator diode board sits right by the exhaust manifold and the phase that failed on mine was the one closest to the manifold. The bearings were tight n smooth, brushes had plenty of life left on the first alternator.
    TnShooter likes this.
  4. Oct 19, 2023 at 11:39 AM
    Plasmech
    Plasmech [OP] Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    I know I probably sound like a little bitch, but I can't seem to wrestle that green field cable connector free.
  5. Oct 19, 2023 at 11:40 AM
    Plasmech
    I honestly thought that replacing alternators at any mileage was a thing of the past, even on the American vehicles.
  6. Oct 19, 2023 at 11:41 AM
    nd4spdbh
    SoCal
    It just really depends on use. A highway driven truck that doesn't see much load (heat n rpms) will go lots longer than a truck loaded down running higher rpms producing more exhaust heat.
  7. Oct 19, 2023 at 11:42 AM
    TnShooter
    Deogee
    STOCK
    Nope. They are like anything else.
    They break eventually.
    The more you use it, the faster it wears out.
    Cleaning the engine bay or getting water in it doesn’t help either.
    Along with mud and dirt…….
  8. Oct 19, 2023 at 11:42 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Denso is pretty much the only reman I'd trust. We use them a lot at work and they've been pretty good
    TnShooter[QUOTED] likes this.
  9. Oct 19, 2023 at 11:43 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Are you pressing the release button on the connector?
    It's still an electromechanical device so they still fail although some last longer than others.
    Keeping a good battery installed definitely helps alternators and starter last longer though.
    Jimmyh likes this.
  10. Oct 19, 2023 at 12:05 PM
    Plasmech
    The one that's on the firewall side of the connector, yes.
  11. Oct 19, 2023 at 2:02 PM
    Waasheem
    Waasheem
    2007 xrunner
    I hate those little release tabs. Sometimes you have to push the connector in, push the tab, you might hear a click, then pull the connector off.
    Another thing that helps is to blow clean with an air blow gun while wiggling pushing pulling the connector. Dirt gets in there and acts like cement holding it together and getting in the way of the tab moving.
    SR-71A likes this.
  12. Oct 19, 2023 at 2:34 PM
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    Just had to replace mine on a 2017 Camry at 68000 miles. You just never know. I baby it too
  13. Oct 19, 2023 at 2:35 PM
    Scotfree
    2021 sr 4x4 2.7
    If you’re replacing it yourself, the alternator, while the belt is off, give all of your pulleys a few rotations in the opposite direction, it makes them happy.
  14. Oct 19, 2023 at 2:37 PM
    Scotfree
    2021 sr 4x4 2.7
    Practice it before turning it on and don’t have any loose clothing or hoody strings or necklaces dangling.
  15. Oct 19, 2023 at 4:39 PM
    #35
    Plasmech
    Why does it make them happy?
  16. Oct 19, 2023 at 5:38 PM
    #36
    Scotfree
    2021 sr 4x4 2.7
    It will just knock any crud loose, if there is any, by spinning the bearings in a different direction.
  17. Oct 19, 2023 at 7:47 PM
    #37
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You get the connector off yet?
  18. Oct 19, 2023 at 8:11 PM
    #38
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I learned this re new/rebuild earlier this year with my 2010. I did the factory reman earlier this year and zero issues since. Mine croaked around 130K miles but I do have an upgraded stereo.
    No way to predict how long you will get from it TBH. See what these tests yield first..mine cost about $300 something so you don't necessarily want to just hang a new one.
  19. Oct 20, 2023 at 10:06 AM
    #39
    Plasmech
  20. Oct 20, 2023 at 11:19 AM
    #40
    ABA180
    East Bridgewater MA
    Yup that's singing all right.
    Bite the bullet and get a factory rebuilt from the local dealer as well as get you a new serp belt (unless you know yours is very recent), couple hours work and you'll be golden.
