Do I have a bad wheel bearing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Plasmech, Sep 24, 2024.
  1. Sep 24, 2024 at 11:33 PM
    Plasmech
    Plasmech [OP] Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    My 2009 with 145k miles started making a "waaaaaa waaaaaa waaaaaa" droning noise at highway speeds. I estimate the period to be maybe 0.8 seconds.
    The Michelin Defender tires are near the end of their life but are worn perfectly evenly and still above the wear bars.
    I thought the noise was coming from the rear but now I wonder if it's coming from the front left.
    It's faster the truck is going, the more pronounced the noise is.
    Intentionally swerving does not interrupt or change the noise.
    Unloading the drivetrain by shifting into neutral at highway speed does not affect the noise.
    Any ideas?
    Thanks.
  2. Sep 25, 2024 at 6:53 AM
    Agoldxj
    Agoldxj Well-Known Member
    James
    Central Pa
    2009 SWB AC
    Could be wheel bearing or the needle bearing in the front diff, they are common to make noise. Search ECGS bushing on here, lots of info. Start at each corner, jack the wheel off the ground and try to pin point it.
    Edit, if you put it in 4wd and the noise stops I believe I read it’s the needle bearing.
  3. Sep 25, 2024 at 9:11 AM
    Plasmech
    Thanks.
    Assuming it's the needle bearing, how long do I have after the noise starts before the vehicle becomes undrivable?
  4. Sep 25, 2024 at 9:23 AM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    If needle bearing, I would change ASAP dont want to ruin front differential.
  5. Sep 27, 2024 at 6:23 AM
    Plasmech
    Taking it in today. Wish my wallet luck.
    303tacoma likes this.
  6. Sep 27, 2024 at 7:00 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Doubt it's the needle brg in the front diff, op isn't complaining of vibration which is the primary symptom of one going bad.
    STacoL likes this.
  7. Sep 27, 2024 at 1:59 PM
    TacoTuesday1
    FL
    Wheel bearings on a passenger vehicle are done at 100k.
  8. Sep 27, 2024 at 6:58 PM
    Plasmech
    Got the truck back this evening.
    ‘Twas the right rear wheel bearing.
    I was also experiencing a clunk sometimes when accelerating from a stop on a hill. Could this have been the cause of that as well?
  9. Sep 28, 2024 at 1:08 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I don't think the clunk was caused by wheel bearing. Best way to find out - go find a hill.
    Clunk can be u-joint, leaf springs, motor/trans mount, center bearing …
    STacoL likes this.
  10. Sep 29, 2024 at 7:25 AM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    My starting off clunk was caused by the carrier bearing.
  11. Sep 29, 2024 at 10:06 AM
    Plasmech
    When my rear wheel bearing was changed, would it have necessitated draining and changing the rear diff fluid as well?
  12. Sep 29, 2024 at 10:06 AM
    Plasmech
    Thanks. I'll give that a try.
  13. Sep 30, 2024 at 6:52 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    ...what was the charge for the rear wheel bearing?
  14. Sep 30, 2024 at 7:08 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    When I did mine, because I just lifted the one side (so tilting the axle up on the side I was working), no gear oil was lost when I pulled the axle. I suppose though, that if lifting from the center or on a lift, some gear oil could be lost, but it's easy enough to check unless your fill plug is stuck, which is a different problem in itself.
  15. Sep 30, 2024 at 2:00 PM
    Plasmech
    @WNYTACOMA
    $1,196.33
    ($676.33 OEM parts + $520 labor)
    WNYTACOMA[QUOTED] likes this.
  16. Sep 30, 2024 at 4:41 PM
    tak1313
    2013 Base 2WD
    HOLY...
    I am so glad I could do it myself...IIRC, all the parts, including a new cylinder, and brakes (decided to do them at the same time), new bolts (because the old ones were fairly rusty), etc., came to about $300 for both sides.
  17. Oct 12, 2024 at 11:23 AM
    Plasmech
    Are real wheel bearings a common premature fail point in these trucks?
    I feel like a wheel bearing should last the life of a vehicle.
  18. Oct 12, 2024 at 12:45 PM
    TacoTuesday1
    FL
    wheel bearings on any vehicle are considered done at max 100k.
    are you a mechanic? Being a mechanic would let you know what the life expectancy of a part is.
    Sprig likes this.
  19. Oct 12, 2024 at 1:23 PM
    Plasmech
    Where exactly is the 100,000-mile wheel bearing MTBF coming from?
    If someone has a truck with 500,000 miles on it and he’s never done a single wheel bearing on it yet, should he immediately stop what he’s doing and change his bearings 5 times in a row lest something bad happen on the next drive?
    STacoL likes this.
  20. Oct 12, 2024 at 1:31 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    I agree life expectancy for wheel bearings on these trucks is 100000 miles. Yes some last a lot longer but when you get to 100000 miles you should be prepared to replace a wheel bearing or two. My left front bearing got replaced at 98000 miles.
    Here’s a little trivia I just calculated. If you are running 30 inch tires that bearing in 100000 miles will make approximately
    4.2 billion revolutions. That’s mind boggling. Hard to fathom any bearing could last that long or longer.
    MadDaddy, jackn7 and 1 Limited Toyota like this.
