Do I have a timing belt or chain?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flyboy718, Apr 26, 2017.
  1. Apr 28, 2017 at 7:35 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The 2TR doesn't have a systemic issue with chains or chain guides breaking. Save your money for other potentially expensive repairs like the manifold air injection pump failing :devil: ($1000+ at the dealer, less if you find a rebuild shop).
    flyboy718[QUOTED][OP] likes this.
  2. Apr 28, 2017 at 7:42 AM
    KenLyns
    Belly of the Beast
    In most timing chain engines (unless you're stupid like Ford), the water pump is not driven off the timing chain, because a leak in the pump would contaminate the engine oil. Consequently there's minimal labor saving to replacing a water pump and timing chain at the same time.
    I think a really stretched chain or severely worn guides would trigger a CEL and some cam/crank sensor correlation codes.
  3. Apr 28, 2017 at 7:41 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You are correct. I assumed way too much and stand corrected. :anonymous:
    My apologies to flyboy718.
  4. Apr 28, 2017 at 7:59 PM
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    ^ This.
  5. Apr 30, 2017 at 7:48 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I must have been lucky. I had one of those. 415K on the odometer when I got rid of it. No problems except for having to rebuild the alternator every 100K. 1983 ALT. was different than many of the others.
