Do I have a TRD?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 99tacosupreme, Mar 25, 2010.
  1. Mar 25, 2010 at 11:20 AM
    99tacosupreme
    99tacosupreme [OP] Well-Known Member
    Kyle
    Southern California
    1999 Black V6 PreRunner TRD
    Pioneer Headunit, Infinity Kappa 6.5" speakers, Alpine Type R sub with Alpine M500 amp, 15% Tint up front 5% in the back, Deckplate mod, Debadged, Bilstien 5100s, Wheelers 1.5"AAL, DDM 55w 6k Lights
    I bought my truck used about 6 months ago and I was wondering if it was a TRD? Its a 1999 toyota tacoma prerunner with no TRD stickers, the original owner says that it never came with any. But it did come with bilstien shocks and a rear differential lock which I thought only came on the TRD edition...?
  2. Mar 25, 2010 at 11:21 AM
    ywen
    ywen Well-Known Member
    Yes you do, unless the shocks and the diff lock button are fake.
  3. Mar 25, 2010 at 11:26 AM
    99tacosupreme
    Kyle
    Southern California
    Ha no they are real and all work. I think the TRD stickers look sick I and I want to put some on but I just didnt want to put them on if my truck really wasnt a TRD.
  4. Mar 25, 2010 at 11:27 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    What kind of rims are on it? Motor and trans? Xtra or regular cab?
  5. Mar 25, 2010 at 11:27 AM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    pretty sure yes unless they were installed after market?
  6. Mar 25, 2010 at 11:29 AM
    Pope953
    Pope953 That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    Sounds like a TRD to me man. :)
  7. Mar 25, 2010 at 11:33 AM
    99tacosupreme
    Kyle
    Southern California
    It has the 15" alloy rims, 3.4l V6 with an automatic tans. It is an extra cab.
  8. Mar 25, 2010 at 11:34 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Sounds legit to me.
  9. Mar 25, 2010 at 11:34 AM
    99tacosupreme
    Kyle
    Southern California
    with only 79,000 miles! :)
  10. Dec 11, 2011 at 6:41 PM
    LEGITacoma
    LEGITacoma Well-Known Member
    Louisiana
    99 Tacoma Prerunner
    Rockford Fosgate T0 in a Ported Box, Hifonics 1000.1, Pioneer AVIC Z-120BT Headunit w/ Rearview Camera
    This makes me wonder is mine is TRD. It has the Bilstein shocks. And the locking Rear differential. It does not have any TRD stickers nor does it say TRD anywhere.:confused: It is a 1999 Tacoma Prerunner Xtra cab. It only has 70k on it too.
  11. Dec 11, 2011 at 6:44 PM
    Pope953
    Wesley
    Asheville, NC
    SR5 Pickup
    Holy thread revival.
  12. Dec 11, 2011 at 7:20 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    eh, its only a year old, there could be worse.
    well if your taco has the blisteins and an apperent factory diff lock and a v6 then you got yourself a trd there
  13. Dec 11, 2011 at 7:47 PM
    wesrunner
    wesrunner Team 4Runner
    Wes
    Louisiana
    It's paid for.
    1999 T4R 4WD V6, Deck plate, B&M trans cooler, LED guages and dome lights, LED reverse lights, 2.5" spacer lift, highway tires.
    So what's worse?
    A necro or a new topic thats been posted a thousand times over...?
  14. Dec 11, 2011 at 9:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    This is legitimate use of the search function and revival of an older thread that seems to fit the situation perfectly.
    Prior to the '98 model year, it was possible to order a truck with an e-locker and it not be a "TRD" model. Having said that, the heart of the TRD package is the locker. My guess is that your truck came from the factory as a TRD. Most likely, someone removed the stickers along the way.
  15. Dec 11, 2011 at 9:32 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    honestly a repost of something that has been asked 1000 times usually gets people more mad. But if you revive a 3 yearold thread to make a stupid pointless comment that is not really needed, thats pretty dumb too. reviving a 3 year old (yes i know this is not a 3 year old thread, its just an example)"do i have a prerunner" thread to ask and/or confirm if you have a pre runner is fine and encouraged. reviving the 3 year old "do i have a prerunner" thread to tell the OP that he does in fact have a pre runner, is pointless and un unnecessary.
  16. Dec 11, 2011 at 10:29 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Indeed! Quite nice to see, for a change.
  17. Dec 12, 2011 at 5:28 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    It could be.
    Keep in mind though you could order the locker from the factory on certain models.
  18. Dec 12, 2011 at 7:35 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    But I thought all V6 prerunners had the TRD package from the factory unless otherwise specified.
  19. Dec 12, 2011 at 9:14 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Not in the US.
