Do I have an A/C problem?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AtomAnt, Oct 2, 2019.
  1. Oct 2, 2019 at 2:02 PM
    AtomAnt
    AtomAnt [OP] Well-Known Member
    Adam
    South Cackalacky
    2019 TRD Sport
    I’ll keep this as brief as possible. 2,000 miles on my 2019 Tacoma. Since I bought it I’ve been thinking the A/C is SUPER cold even on low. Almost so cold I wish there was a lower setting. While driving today, I noticed the air didn’t feel quit as cold for a few seconds then it improved. The cycle continued to change about every 5 seconds and coincided with the compressor cycling on/off. Only time it doesn’t do this is on the high setting. Watched the compressor on each setting. A/C on high, the compressor pretty much stays on. A/C on medium, compressor is on about 20 sec. and of for 5. A/C on low, compressor is on for 5 sec and off for 5 sec. Should it cycle that much? It was in the low 90’s and I was in full sun while this was going on.
  2. Oct 2, 2019 at 3:16 PM
    Burro09
    Burro09 Well-Known Member
    Miami, FL
    2017 Tacoma TRD Pro Cement MT
    Mine cycles within a few seconds too when the fan is on low and cooling demand is low. Normal.
    Im guessing you either have a non auto climate control truck, or you are using the auto climate control on LO.(fullblast cold temp)
    The vent temp will always vary a few degrees between compressor cycles. Either yours is swinging too much, or you are sensitive to vent temps. Stick a thermometer in the vent and check.
  3. Oct 2, 2019 at 3:52 PM
    AtomAnt
    Adam
    South Cackalacky
    2019 TRD Sport
    I think it is probably normal. It’s only a few degrees difference. I compared the cycling to that of my wife’s 4Runner and it’s pretty much the same. I don’t feel the temp change on hers but as I said it’s barely noticeable so probably normal. I notice things like this then start worrying something’s not right. The truck is still new to me so I don’t have everything figured out just yet.
  4. Oct 2, 2019 at 5:00 PM
    ryan760
    ryan760 Well-Known Member
    Normal. The compressor cycles on and off based on evaporator temperature... off around 35 degrees, and on around 45 degrees... so, you will see about a 10 degree temp swing during normal operation.
    FWIW, temp swings are greater when fan speed is higher, so use a lower fan speed to lessen the swings.
