Do I Have An LSD or Open Diff?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Buffco, Jun 17, 2012.
  1. Jun 17, 2012 at 6:56 PM
    Buffco
    Buffco [OP] Well-Known Member
    I have a 1999 Taco, 2.7L 3RZ, 5 speed manual, 4wd base model. I don't know if the rear is a limited slip or open differential.
    How can I find out? Or do any of you know whether this truck came with one or the other?
    Thanks..
  2. Jun 17, 2012 at 7:02 PM
    trooper12
    trooper12 Well-Known Member
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
    maxtrac 4" lift spindles, wheelers 1.5" 3 leaf pack. nothin special...
    An easy way to check if you have an open diff is to jack up the axle so both rear tires are off the ground, spin one tire. If they both spin the same way you have a LSD, if they spin opposite ways you have an open diff.
    And be sure to chalk the front wheels when your lifting your truck.
    Hopefully this works for you
  3. Jun 17, 2012 at 7:13 PM
    Buffco
    Thanks a heap.
  4. Jun 17, 2012 at 10:59 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Our Tacomas didn't come with an LSD option.
  5. Jun 17, 2012 at 11:07 PM
    Denim Dan
    Denim Dan Confusion
    Erick
    Visalia Ca
    96 4x4 reg cab
    You probably have the same as me open diff.
  6. Jun 18, 2012 at 1:48 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    One tire fire good buddy.
  7. Jun 18, 2012 at 5:57 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    I thought there were only two options for Tacomas; open or electronically locked.
  8. Jun 18, 2012 at 7:08 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Found it for you...
    MainerDave19995VZ likes this.
  9. Jun 18, 2012 at 11:44 AM
    Buffco
    Thanks guys. Side note, but related question: Where can I find out what all the other codes are on the VIN sticker on the door jamb? After looking and looking, I think what I am seeing is my axle code is a B02A.
    But there is a group of numbers and letter codes there that I have no clue what they refer to. Any one know?
  10. Jun 18, 2012 at 1:00 PM
    Gooch
    Orange County CA
    My source shows limited-slip being introduced as an option in 2005 (second gen).
  11. Jun 18, 2012 at 3:51 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    No TRD/No Locky/No LSD/ just open diff
  12. Jun 18, 2012 at 7:13 PM
    Gooch
    Orange County CA
    My door says B03A, which according to the table, means I have an open diff, but I actually have a factory locker.
    I tried a few sites that have 'VIN decoders' but they didn't come up with axle information.
  13. Jun 19, 2012 at 11:38 AM
    MowTaco
    Kansas
    You do have an open diff... The differential itself is open until it is locked. The E-locker is an option that can be added to many of the different axle codes, so it doesn't need a separate designation.
    Those other codes there could be anything. Most likely paint codes/interior color/production info. I'm sure there's a way to decode them online somewhere.
  14. Jun 19, 2012 at 1:13 PM
    Gooch
    Orange County CA
    I guess my issue is that I have not found a reliable source that says that a limited-slip differential was ever available in a Gen 1 Tacoma.
    I was always told that you either have an electronic lock or you don't and there is no 'other' configuration.
    Has anyone ever heard of a factory LSD on a Gen 1?
  15. Jun 19, 2012 at 1:22 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Pretty sure all 1st gens either had the E locker option with TRD, & no Locker / LSD option for non TRD models
    I never heard anyone being able to get the E locker on a non TRD , this probably changed in '05 tho'....
  16. Jun 19, 2012 at 1:53 PM
    tan4x4
    Rick
    Folsom, CA
    The VIN doesn't have codes for options, other than if its 2wd or 4wd, cab type, motor size, or dual air bags. The last 6 digits is just a serial number.
    Tranny, axle, and color have their own separate codes on that driver-side door plate. My paint code is 4M4 (tan). My axle code is B04A ( 8", 4.56, open). Tranny code is A340F (4-spd auto).
  17. Jun 19, 2012 at 5:39 PM
    Gooch
    Orange County CA
    FWIW, attached is a 2000 Tacoma brochure. I realize it's not the final word on the subject, but anyway, there apparently was no LSD option that year.
    Like I said earlier, I think the option was first seen on the 2nd generation in 2005. Also attached is the 2005 brochure which does list the LSD as an option.
  18. Jun 19, 2012 at 6:13 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    I know that I use to think that what you said was true. However, me and my buddies are building a road race truck (Chevy S10) and we were looking for a G80 rearend (we since quit and found an Auburn posi) which means "locked" depending upon which type of G80 was in that axle. Regardless, we thought that: lift the truck, spin the tires and if they went opposite, meant it was open.
    However, that isn't the case (at least not as a general rule of thumb). We checked about 3 rearends that were "locked" (Auburns or Eatons) and they spun when lifted the same way that we thought an "open only" diff spun.
    My point, that may be misleading.
  19. Jun 20, 2012 at 5:07 PM
    trooper12
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
    This is true, but the LSD's your talking about are open until the LSD kicks in then the rear end locks. I assumed that the older trucks have the lsd's with the clutch packs in them, with those the wheels will turn in the same direction. Eaton's are only locked when you at on the gas, when you are coasting they are an open diff. So when the back wheels are spun, they will turn in opposite directions because the diff is open at that time.
  20. Jun 20, 2012 at 9:15 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    I made a thread about this like a week ago..... we must get to the bottom of it! Im figuring its for the 4runners. Did any of them have an LSD? That could be why there is a C option in the code..
