do i have an oil cooler?????
Discussion in '1st Gen. Tacomas (1995-2004)' started by biggecko, Jan 1, 2012.
  1. Jan 1, 2012 at 7:43 PM
    biggecko
    biggecko [OP] Well-Known Member
    Tarek
    Apex,nc
    2000 TRD SR5 pre-runner v6 3.4
    nerf bars, deckplate mod, billys 5100 all the way round with an aal in back
    i am placeing an order from rock auto and getting all the parts thogether to do my timing belt job and its asking me if i have an oil cooler or not, how do i find out???? i have a 2000 taco 2wd with trd prerunner sr5 and ive got the 3.4 v6 plsss help :)
  2. Jan 1, 2012 at 7:46 PM
    biggecko
    Tarek
    Apex,nc
    ima go have a look, is it attached to the radiator?
  3. Jan 1, 2012 at 7:53 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    i highly doubt you have either
  4. Jan 1, 2012 at 7:54 PM
    biggecko
    Tarek
    Apex,nc
    it says w/ oil cooler, w/o oil cooler
    my condensor is right under my grill , if u look at it frlom under you see the radiator, and then a thinner radiator bout half the size of my radiator right in fronlt of it, would that be the oil cooler?
  5. Jan 1, 2012 at 7:55 PM
    biggecko
    Tarek
    Apex,nc
    i see tranny fluid lines running into my radiator so i know i have a tranny cooler, i just didnt know bout an oil cooler
  6. Jan 1, 2012 at 8:38 PM
    biggecko
    Tarek
    Apex,nc
    would the a/c system have anything radiator like?
  7. Jan 1, 2012 at 11:08 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    IIRC all the auto's have a line running through the radiator to cool the tranny fluid...not a tranny cooler; that would be an extra little radiator, not piggy backing off the existing radiator.
  8. Jan 1, 2012 at 11:44 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The difference is in the water pump. Take a look at your water pump. Does it have the extra outlet?
    According to Rock Auto's menu system, if your shifter is on the floor, order "with oil cooler", also known as "Outlet Tube At Thermostat" or "Bypass Tube".
  9. Jan 3, 2012 at 10:42 AM
    biggecko
    Tarek
    Apex,nc
    I went to yotatech. And foud the service manual and I do have an oil cooler, what was throwin me off was the mini radiator in front of my existing radiator, thanks for the help u guys, and if u look uner your engine parallel to the oil filter their is a cylinder type thing with hoses comin out that is the oil cooler
    4XMountains likes this.
  10. Jan 3, 2012 at 10:43 AM
    biggecko
    Tarek
    Apex,nc
    Getting to the water pump is too much work lol...
  11. Jan 3, 2012 at 2:35 PM
    KenLyns
    Belly of the Beast
    Cool. Looks like the 1st Gen. oil cooler is similar to those on 2nd Gens. with tow package.
